Thread: tie rod end wont budge
Results 1 to 20 of 23
  1. #1 tie rod end wont budge
    Jacksonville, Fl
    so i need some help... im trying to pop off my tie rod end and its not going anywhere. its not corroded because its almost brand new, maybe 8k miles on it? other side popped off after a few wacks with a mallet. ive been battling this thing for hours. ive used a mallet, used a blow torch, mallet again, and even applied pressure from the bottom with a jack while hitting it with a mallet but im getting no luck. the castle nut is off and i broke the locking nut loose. any ideas what else i could do?
  2. #2 Re: tie rod end wont budge
    so the joint is stuck in the knuckle still?
    Get a bigger hammer??
    or just rip the boot away and cut it off and buy a new ti rod.
  3. #3 Re: tie rod end wont budge
    GTP Level Member buickman104's Avatar
    NYC
    There is a proper tie rod end removal tool if all else fails you could try that.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: tie rod end wont budge
    Donating User Odi's Avatar
    Chicago South Suburbs
    liquid wrench helps getting sh1t off. same goes for pb blaster.
  5. #5 Re: tie rod end wont budge
    one of these will work. hammer it in, it will kill the boot though.
  6. #6 Re: tie rod end wont budge
    GETCHA fork FTW
  7. #7 Re: tie rod end wont budge
    GrandPrix Junkie
    St. Louis
    Fork that. If it's still stuck in the knuckle, then just screw the castle nut back onto it just until the end of the tie rod is even w/ the top of the castle, and then back it off one turn. Get a Ford wrench and smack the castle nut directly upwards and it will pop. I don't even own one of those fancy fork thingys and I've done tie-rods for years this way. Have yet to have one not come out. If not, then get a bigger hammer and jack the car up higher so you can get a good CENTERED swing on it. Pop goes the weasel.
  8. #8 Re: tie rod end wont budge
    Jacksonville, Fl
    ya idc if i got to buy another tie rod end at this point. i was thinking about cutting the thing off anyway. and if i wanted a bigger hammer, i would literally need a sledge hammer. the one im using is already about 10 pounds haha. ill look into the tool. probably see about renting one. thanks for the suggestions guys
  9. #9 Re: tie rod end wont budge
    GrandPrix Junkie
    St. Louis
    Or you can heat up the outside of the knuckle w/ a torch to get it to expand and then smack the tie rod. Done that a few times too.
  10. #10 Re: tie rod end wont budge
    Donating Users
    Mar 2012
    Toms Riviera
    2 decent weight hammers, swing both at opposite sides of the arm, this temporarily deforms the taper and releases the grip.
  11. #11 Re: tie rod end wont budge
    Jacksonville, Fl
    already had tried a torch. got the removing tool and it popped out no problem. best part is, the boot still lives (:
  12. #12 Re: tie rod end wont budge
    NYC
    There is a proper tool for most jobs.
  13. #13 Re: tie rod end wont budge
    I dislike the tool, they should have named it boot killer.
    If you don't mind us asking...why are you taking off the tie rod end?
  14. #14 Re: tie rod end wont budge
    Donating Users
    Mar 2012
    Toms Riviera
    I agree, I use mine only when replacing the Tie Rod/ Ball Joint, And Of Course for the tool's Obvious intended use...My Wife was skeptical even after I showed her the box it came in, Clearly labeled "Pickle Fork". (You earn a Gold Star if you know what kind of pickle I'm about to nosh on).
  15. #15 Re: tie rod end wont budge
    Jacksonville, Fl
    im pulling off the tie rod because im also replacing the rack and pinion while i have the motor out
    and my boot came out fine. maybe i just got lucky
  16. #16 Re: tie rod end wont budge
    that's not the tools he's talking about its the one that is like a c shape that has a bolt that runs through it to push the tierod out right?
  17. #17 Re: tie rod end wont budge
    I think what you are talking about is a pitman arm puller, C shaped with a drive bolt.
    the ad i got it from says pitman/tie rod puller.
  18. #18 Re: tie rod end wont budge
    Yeah that's what i was thinking of.
  19. #19 Re: tie rod end wont budge
    Donating Users
    Mar 2012
    Toms Riviera
    Good luck with a pitman arm puller. The whole concept of the taper is that it stretches ~6 thousandths of an inch when torqued, so pushing down on the top-or hammering on the top of the stud only serves to "bulge" the male element of the taper, thereby making it tighter still. Not to say you won't get lucky once in a while, but if the taper was originally assembled with oil or grease (BIG NO NO), you're in for a fight. 14 degrees of included (7 per side) or less will lock, steel on steel. Somewhere around 16 or 17 degrees and above will free release. I may be off a bit, but I'm too lazy to look it up in the Machinerys' Handbook right now...and nobody thought my pickle fork was funny :C
  20. #20 Re: tie rod end wont budge
    ill have to look for it next shopping trip, could be good lol
  1. Spark plugs boots will not budge - grrr....!
    By Elite6 in forum General Tech Discussion
    Last Post: 02-17-2012, 11:42 PM
  2. a/c wont work and heat wont go to floor PLEASE HELP!!
    By Brett Muszynski in forum Introductions/Noob Questions
    Last Post: 02-10-2012, 05:43 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. sc pulley wont budge
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2011, 09:09 AM
  5. Headlight Stuck!! Clip won't budge!
    By pr84704p in forum 04+ Specifics
    Last Post: 01-22-2010, 08:47 PM
