Thread: metal on metal sound
Results 1 to 10 of 10
  1. #1 metal on metal sound
    GT Level Member Toms04compg's Avatar
    Michigan
    Are you supposed to be able to wiggle your caliper when tire is on and on pavement? Ive got a nasty noise over bumps
  2. #2 Re: metal on metal sound
    Kansas
    No need to create two threads for this issue.
  3. #3 Re: metal on metal sound
    Michigan
    Sorry man im so flustered between misfire and this suspension or brake issue.
  4. #4 Re: metal on metal sound
    The Boss Iceman6669's Avatar
    Jun 2011
    Where is MI are you....
    2011 F-150 Yote powered
  5. #5 Re: metal on metal sound
    pull the brakes off and take a look at them and see how they look.
  6. #6 Re: metal on metal sound
    Michigan
    Waterford mi..... I took the tire off rotor real wobly and ofcourse caliper wiggles even more. I dont recall ever being able to wiggle a caliper when sitting
  7. #7 Re: metal on metal sound
    Jun 2011
    Try pumping the breaks then try moving it...
  8. #8 Re: metal on metal sound
    They are able to move a little. Just pull it apart and look at everything.
  9. #9 Re: metal on metal sound
    Michigan
    It will stop first gtp so not sure how the brakes would feel. It stops pedal seems fine i can still wiggle it now that its pumped and on pavement
  10. #10 Re: metal on metal sound
    Apr 2009
    Fort Worth TX
    ^^ Especially the caliper bracket bolts and sliders.
  1. Scrap metal!
    By GAFF in forum Off Topic Discussion
    Last Post: 11-24-2010, 02:09 PM
  2. Loud Metal Clanking sound
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 02:05 PM
  3. metal sound/foam
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 12:45 AM
  4. Metal Clip
    By Red97GPGT in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 09:00 PM
