Thread: Comp G OE spring replacement
Results 1 to 2 of 2
  1. #1 Comp G OE spring replacement
    SE Level Member Infinity9999's Avatar
    Dec 2008
    Brookfield, WI
    Getting replacement OE springs for my 04 Comp G. My mechanic said that he can't find the rear Comp G-specific springs (based on my VIN) anywhere. Are the spring rates different between Comp G and non-Comp G? I know the struts are different. Could I just use regular GTP springs? Or maybe go with GXP springs in the back? I think GXP ones will raise the car up, though. He's got Comp G springs for the front, so I only need something in the rear. Any thoughts?
    04 Black GTP Comp G
    Mods: 3.2 pulley, SSIC, Wizair, AL104s, OBX headers, VS cam, 105# springs, 42# injectors, PowrTuner
  2. #2 Re: Comp G OE spring replacement
  1. Comp G trans in a non Comp G
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2011, 10:31 PM
  2. Compressor psi during valve spring replacement
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2011, 07:23 AM
  3. Regal GS Spring Rate vs 40th Anniversary Spring Rate
    By 40th in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2011, 10:57 AM
  4. New Replacement Mono Leaf Spring
    By willwatsonfl in forum Brakes/Suspension/Chassis
    Last Post: 06-23-2010, 11:16 AM
  5. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
