Thread: clunking raddleing noise in rear with vid
Results 1 to 4 of 4
  1. #1 clunking raddleing noise in rear with vid
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    da fack is this noise? its horible. i want people turning heads at the blower not that pos noise. rear driveside
    VID_20120305_190220.mp4 video by 1gt420 - Photobucket
    Smgpfc
  2. #2 Re: clunking raddleing noise in rear with vid
    The video isn't very good but it sounds like your brake shield is rubbing the rotor.
  3. #3 Re: clunking raddleing noise in rear with vid
    pull the wheels off and check your brakes, the slider pins may be dry and the pads are dragging the rotor a bit, or maybe the e brake is out of whack and hitting the drum part of the rotor. could even be the squealers on the brake pads if you are out of pads.
  4. #4 Re: clunking raddleing noise in rear with vid
    Dec 2010
    plymouth ma
    ill get a better vid tomoro and take a look
    Smgpfc
  1. Clunking noise in front end 04 gtp!!!!
    By justin98 in forum General Tech Discussion
    Last Post: 11-08-2011, 03:19 PM
  2. clunking noise
    By jessejj79 in forum General Tech Discussion
    Last Post: 02-28-2011, 12:49 PM
  3. Clunking Noise...
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2011, 09:17 PM
  4. Bad clunking noise and bad acceleration
    By ill12will8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2010, 03:00 PM
  5. clunking noise?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2009, 02:55 AM
