Thread: dang mileage,A dd in need of help
Results 1 to 20 of 22
  1. #1 dang mileage,A dd in need of help
    TN
    Today I went to get my tires balance due the car shakeing on turns but I got a big surprize. Both front hubs and outer tie rod ends are shot.
    The shop told me it would cost 783.00 I want see if I can do it cheaper
    Can I get some help on what brands to buy and where to get them.
    Also any directions on installing them
    88 fiero formula l67
    04 ninja
  2. #2 Re: dang mileage,A dd in need of help
    Buy 2 outer tie rods for 15 bucks a piece at O'Riellys...get 2 new hub assemblies from AutoZone with a lifetime warranty for $145 a piece. Do it yourself and buy a 6 pack and have fun.
    There...I just saved you over $450 bucks
  3. #3 Re: dang mileage,A dd in need of help
    TN
    Alright I will take the tie rod for 15
    If someone would, check this http://www.grandprixforums.net/wheel...nds-35096.html it explains that Auto Zone and the others isn't good and boost Timken or SKF 2nd post do they have a reason
    04 ninja
  4. #4 Re: dang mileage,A dd in need of help
    Donating User Odi's Avatar
    Chicago South Suburbs
    id opt for timken. check rockauto for prices, they might have it pretty cheap.
  5. #5 Re: dang mileage,A dd in need of help
    Florida
    Yeah, doing the labor yourself will save you a **** ton of money...Get a repair manual if you dont already...it will be a time/headache saver.
    As far as the wheel bearings...I've had my Advance Auto Parts set for about 50kmiles...without a problem...and they also have a lifetime warranty. Just my .02
  6. #6 Re: dang mileage,A dd in need of help
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Rock auto has the Timkens for $100 each for the 04z I don't think the price would differ that much for your gen.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  7. #7 Re: dang mileage,A dd in need of help
    TN
    Alright everyone thanks for the help, I will check prices on the auto stores
    2nd this may be just my bad, but I had never got on rock auto until today Where are the hubs there the only 2 I found where 200+
    04 ninja
  8. #8 Re: dang mileage,A dd in need of help
    TN
    That was fun,but now hours after I see a how to post on this site which said,I should have got new hub bolts. I just lock tie the bolts, is that ok or not
    04 ninja
  9. #9 Re: dang mileage,A dd in need of help
    GT Level Member mkyota1's Avatar
    Daytona, florida
    You are fine. It is common practice to reuse the bolts.
  10. #10 Re: dang mileage,A dd in need of help
    Pittsburgh
    It is a PITA to get new hub bolts, they are dealer only and I went to 3 dealerships to find one that had them when I rounded off one.
    Durkz 04 Silver GT2
  11. #11 Re: dang mileage,A dd in need of help
    TN
    Ok thanks, I was just trying make sure I wouldn't have the problem of a hub sliding out while im driving down the road.
    04 ninja
  12. #12 Re: dang mileage,A dd in need of help
    when you do the tie rods just crack the retainer nut and leave it on, while the tie rod is still connected to the spindle, then remove the tie rod and leave the nut there, replace tie rod and tighten the nut up.
    but don't do this until you have a set appointment with a alignment shop you'll be close but not that close and could wear out the parts if driven just a few days. tie rods are quick and easy to do, takes 30 minutes to 45 minutes tops for both sides.
  13. #13 Re: dang mileage,A dd in need of help
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Any idea what size wrenches/sockets i will need. Want to make sure i have before starting outer tierods. Any hints ?
    1997 Red GTP 182000 miles stock
  14. #14 Re: dang mileage,A dd in need of help
    Quote Originally Posted by GTP in RTP View Post
    i cant remember the bolt sizes, 18 mm maybe, so pull the tire, you will see a lock nut at the end of the tie rod, crack that bolt first, just make it loose, then un bolt the outer side that goes through the steering knuckle, after the bolt is off, if you have a baby sledge, 5 lb'er, or even regular hammer, hit the knuckle where the tire rod goes through the knuckle, it will pop loose after a good shot or 2 or 3, you should see some dents in the knuckle from when the job was done last, if ever done before. then un screw the tie rod, leave the lock nut in place, then screw the new tie rod on to the lock nut, tighten it all up, take it to the shop for an alignment.
  15. #15 Re: dang mileage,A dd in need of help
    SE Level Member tstaller2005's Avatar
    minneapolis
    I had to replace the same parts as you did and I just went to my local Junk yard and bought the pieces off Grand Prixs with lower miles and spent 125.00 on 2 control arms a tie rod end and a left hub assembly.
  16. #16 Re: dang mileage,A dd in need of help
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    amazon has timkins for less than $100 and free shipping.
    don't buy $15 tierod ends --- it's simply stupid. get moog and be done with it.
    you can get your alignment awfully close if you measure from the frame rail to the straight edge of the front knuckle --- measure before you break things loose and you'll be very good.
  17. #17 Re: dang mileage,A dd in need of help
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    AC delco 150$ each with lifetime warranty i think. and not sure but i think AC delco is what the gm dealers use if not then its damn close to stock
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Advance auto has the Moog wheel bearings for $132...use ccabin for a promo code and get $40 off. Do separate orders and get $40 of each. I got the Moog tie rod ends too. I had about $350 in mine including the $55 alignment once it was done. Pretty simple job with the right tools.
    Sent from my DROID RAZR using Tapatalk
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  19. #19 Re: dang mileage,A dd in need of help
    Toledo, Ohio
    There are a couple good youtube videos too of the tie rods and wheel bearings done on a Pontiac or GM vehicle. They take you step by step and also go e you some helpful tips.
  20. #20 Re: dang mileage,A dd in need of help
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by firstdue View Post
    thanks guys, trying to smooth ride , had tires balanced , that helped a lot, hubs probably after tie rods. tires and shocks seem good.
  1. Dang Rocks!
    By burgundybullet in forum The Rant Forum
    Last Post: 03-18-2011, 05:39 PM
  2. Why am I getting bad Gas Mileage?
    By JDCMoney in forum General Tech Discussion
    Last Post: 06-10-2010, 01:34 PM
  3. Broke the dang petcock..now what?
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-07-2009, 07:26 PM
  4. Mustang Bullets...dang!!!
    By UR LOSN in forum Tires & Wheels
    Last Post: 04-01-2008, 06:02 AM
  5. Dang it
    By UR LOSN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2008, 09:02 PM
