Thread: Different Grindings
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: Different Grindings
    cv joints can click when turning or vibrate on the highway when bad.
  2. #22 Re: Different Grindings
    oh and should you buy from that site, google partsgeek promo codes, the more you can buy at once aka the more you spend you can find a nice discount on top of their already lower than the auto parts store price. auto zone wants like 65 or 70 per lca, screw that ill wait for the shipping lol and my order came in less then a week.
  3. #23 Re: Different Grindings
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Good because things get expensive quick whew...lol My tax return will be gone by he time im done.
  4. #24 Re: Different Grindings
    by all means do shop around, but over and over when i search a part, these guys have better prices and better shipping rates.
  5. #25 Re: Different Grindings
    Jan 2012
    Sturgis, MI
    Well i will definitely check out that site. Thanks so much for the ideas and quick responses. Google wasn't cutting it because i couldnt find much specifically for Grand Prix's...
  6. #26 Grinding Howling Noise? [Photos Added (2.7.2012)]
    Jan 2012
    Sturgis, MI
    The post i posted last night was concerning different grindings i was experiencing and got lots of possibilities of what could be going bad. Heres the link to the post. http://www.grandprixforums.net/diffe...ngs-57417.html
    I noticed tonight that a new noise appeared, most likely because of not being able to jack my car up to; first of all, change my brake pads because they need to be done and 2nd check and fix all other problems but because i dont know anyone that can help me, i mean i do but i cant ever get ahold of them or even depend on them for that matter.
    I filmed the noise best i could and i hope with this new noise i can get ideas from. Take a listen from slowing from 60mph to 35mph.
    Last edited by Adidasdude1989; 02-07-2012 at 09:11 PM. Reason: Photos uploaded on post #7
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  7. #27 Re: Grinding Howling Noise?
    GT Level Member outonthetiles's Avatar
    Dec 2011
    Herkimer, NY
    Sounds like a wheel bearing to me. Does it get louder or quieter when you turn?
    If it gets louder when you turn right its the left wheel bearing. If it gets louder when you turn left its the right wheel bearing. Most likely one of the front ones.
    Other than that, maybe a halfshaft?
    Edit: I didn't read your other thread, not sure if this was already discussed.
  8. #28 Re: Grinding Howling Noise?
    Sounds like wheel bearings I'd just change both of them if i was you.
  9. #29 Re: Grinding Howling Noise?
    Jan 2012
    Sturgis, MI
    Quote Originally Posted by outonthetiles View Post
    No it wasnt, this is a whole new noise and by the way, when i turn right it does seem to get louder.
    I have been thinking about that all this time actually.
    Miles: 170-XXX
    Engine: 3.8L V6
  10. #30 Re: Grinding Howling Noise?
    Dec 2011
    Herkimer, NY
    I would start by replacing the front left bearing with a timken..
  11. #31 Re: Grinding Howling Noise?
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Ever solve this sound problem Adidasdude1989? I've got one very similar. I replaced the front left wheel bearing because thats where is seemed loudest....with no change. Mine doesn't seem to change much when turning, just gets louder with speed. It sounds like the loud hum that i had from snow tires on my first car. No vibrations or any other noises on mine.
  12. #32 Re: Grinding Howling Noise?
    Jan 2012
    Sturgis, MI
    Quote Originally Posted by firstdue View Post
    Im not actually quite sure. I went and bought brakes, went to a garage and took off the left front tire and took out my brake pads and seen that my brakes are fine. I then put the tire back on, tightened the lug nuts and shook the tire to check for bad bearings, there was no play. I then spun the tire and didnt hear what i hear driving. Then i proceeded to the right front tire, did the same exact things to the right as i did with the left but then i noticed i had no sway bar. My dad freaked and was like "whaaaat the f...". Told me that i need to get that replaced. An kinda explained that the noise i was hearing was most likely coming from that tire because he took a ride with me and said that it seemed louder from that tire.
    I took photos so everyone click the photos and see what we saw.
    Miles: 170-XXX
    Engine: 3.8L V6
  13. #33 Re: Grinding Howling Noise? [Photos Added (2.7.2012)]
    Jan 2012
    Sturgis, MI
    Any other replies?
    Miles: 170-XXX
    Engine: 3.8L V6
  14. #34 Re: Grinding Howling Noise? [Photos Added (2.7.2012)]
    Yoga city
    nice sway bar is missing a portion of it nice, replace and just do both the bolts cause i garuntee if it looks like that now. those bolts are dust un the rubber bushings
  15. #35 Re: Different Grindings
    One problem, one thread. Thanks
  16. #36 Re: Different Grindings
    Toledo, Ohio
    I had to replace the front sway on my 00 GT and at that time they were on a national backorder. It took like 3 months to get a new one. Not a really tough install if i remember correctly.
