Thread: CV Axle Leaking trans fluid?
Results 1 to 4 of 4
  1. #1 CV Axle Leaking trans fluid?
    SE Level Member GP_Kid18's Avatar
    May 2008
    Palatine,Illinois
    I recently replaced my passenger side CV axle, but when I had pulled the axle out a good amount of trans fluid came out of the opening for the CV axle, I have never had this happen before, is there something wrong or did I just just lucky the other times? any advice would be great, thanks.
  2. #2 Re: CV Axle Leaking trans fluid?
    If the fluid was above the level at which the axle is at, trans fluid will come out.
    If trans fluid continues to come out after you have replaced it, the seal is prolly ripped and needs replacing.
  3. #3 Re: CV Axle Leaking trans fluid?
    I typically jack up the passenger side when doing that axle and typically it won't leak out. If I jack the front of the car, I'll see some fluid. Follow what FFDP said and you can't go wrong.
  4. #4 Re: CV Axle Leaking trans fluid?
    May 2008
    Palatine,Illinois
    Great! Thank you both very much!!
  1. Leaking Trans Fluid (by axel)
    By TDgrand in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-06-2010, 03:20 PM
  2. Leaking oil or trans fluid?
    By zildjian102 in forum General Tech Discussion
    Last Post: 10-30-2010, 02:17 PM
  3. 98 GTP leaking tranny fluid
    By millfire517 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2009, 11:02 AM
  4. Leaking tranny fluid
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2009, 07:00 AM
  5. Fluid Leaking out of Axle Seal Still
    By Metallistar in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 04:39 PM
