Thread: 04 Brake Problem
Results 1 to 19 of 19
  1. #1 04 Brake Problem
    Jan 2012
    Baytown
    Problem started about 2 mo. ago. When backing out of the driveway brake pedal would go down further than normal. Problem starting occuring more often when driving as well. Had a brake fluid leak in the rear passenger tire so I replaced both rear calipers, turned rotors, and new set of Wagner pads (semi-metallic front, ceramic rear). Had local mechanic do the work but the pedal is still going down occasionally (scares the hell out of me). Mechanic said he bled the lines and thinks it's an eletronic issue. In fact, he didn't want me to drive the car home as he feels it is a safety issue. The car has approx. 117K miles on it and my 18yo son is the primary driver so I don't feel comfortable letting him drive the car until I know the problem is fixed for sure. Another note, when I bought the car I used to be able to push the traction button and the icon would show up but it hasn't displayed in a couple of years. I don't know if this has anything to do with the brake issue. Please help!
  2. #2 Re: 04 Brake Problem
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Does it make a groaning noise when it happens? Maybe you can feel something like a buzz or vibration in the brake pedal?
  3. #3 Re: 04 Brake Problem
    Jan 2012
    Baytown
    Since I bought the car it has always made a groaning/rubbing noise when backing out of the driveway or after the car had been turned off. I just had the worked on last Wednesday so I don't know if it's still there.
  4. #4 Re: 04 Brake Problem
    Jan 2012
    Baytown
    Just spoke to the wife and I asked her what exactly happened yesterday. We've been careful with the braking since we got the car back so I asked her to start braking earlier than usual during normal stops. She was coming up to a stop and she started applying the brakes and she felt resistance on the pedal and then all of a sudden the brake pedal went down to the floorboard. Scared the crap out of her!
  5. #5 Re: 04 Brake Problem
    May very well be an ABS sensor issue. If the TC light doesn't come on, it may be because the ABS is malfunctioning (not sure how the lights work in '04+), as ABS controls TC. Start the car, when you first turn the key to the run position, (when all the lights light up and things start ding-donging and such), and check to make sure that the ABS light comes on momentarily. If you didn't know, to check that the various indicator lights are working is the purpose of them all coming on at startup.
    The car may be sensing a skid due to malfunctioning ABS sensors; in an effort to correct it, the computer severely limits your braking power in order to regain traction.
    This is how this works to my understanding, there are guys on here who spend more time under their cars than I do, so maybe some of them will chime in.
  6. #6 Re: 04 Brake Problem
    Jan 2012
    Baytown
    Thanks for the info. At least I'll have something to tell the mechanic.
  7. #7 Re: 04 Brake Problem
    Sounds to me like your master cylinder is bad. Had that happen on my dads 78 chevy one time and i almost t-boned one of my friends.
  8. #8 Re: 04 Brake Problem
    Jan 2012
    Baytown
    I bought the master cylinder ,just in case, but wouldn't the brakes be acting up all the time and not just sporadically?
  9. #9 Re: 04 Brake Problem
    On dads truck it was only every once in a while
  10. #10 Re: 04 Brake Problem
    Texas
    Are you losing any brake fluid after the brake line fix?
    It could also be the brake booster has a vacuum leak or the check valve going into the booster is going bad.
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: 04 Brake Problem
    Jan 2012
    Baytown
    Didn't have the car that long after I got it back from the mechanic so I can't answer your question about the leak. My wife dropped it off yesterday so he can look at it tomorrow. I just thought of another weird issue. I just bought a new set of tires for the car because two of the previous tires had worn down completely. The previous tires were BF Goodrich Precept that were supposed to be good for 70K but I only got 44k out of two of them. The rear tires were still ok but the front tires were damn near bald. I rotated the tires every 5k miles so I find it weird that not all four wore out evenly.
  12. #12 Re: 04 Brake Problem
    utah
    I'm gonna second a master cylinder issue
  13. #13 Re: 04 Brake Problem
    Donating Users GrandpaAl's Avatar
    Salt Lake Utah
    It's been years since I saw a master cylinder starting to fail like this, but I too think it's the MC. If you pump the brake peddle does it immediately firm back up? It seems that gently pushing down on the peddle allows the fluid to leak by in the MC, and a quick jab at the peddle doesn't, when the MC is pitted inside.
  14. #14 Re: 04 Brake Problem
    It's not common at all for a master cylinder to do that in a modern vehicle, however, definitely take it into consideration because it would cause your issue. And if you say you never hear "pump/groaning" noise when it happens, the MC is likely leaking.
  15. #15 Re: 04 Brake Problem
    Jan 2012
    Baytown
    The pedal definitely firms up after pumping. I'm having the MC changed out right now. Thanks for all the help and advise.
  16. #16 Re: 04 Brake Problem
    utah
    Let us know the verdict
  17. #17 Re: 04 Brake Problem
    Jan 2012
    Baytown
    Received the car late Tuesday and drove the car most of the day yesterday. Looks like the problem is fixed. Thanks again for all the help.
  18. #18 Re: 04 Brake Problem
    Awesome glad to be of help
  19. #19 Re: 04 Brake Problem
    utah
    glad to hear
  1. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
  2. brake booster vacuum problem
    By comongoose in forum Brakes/Suspension/Chassis
    Last Post: 03-20-2009, 12:46 PM
  3. Antilock Brake Problem
    By $03gp/gt$ in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2009, 05:33 PM
