Thread: Popping noise in rear?? HELP
Results 1 to 5 of 5
  1. #1 Popping noise in rear?? HELP
    SE Level Member 3R1CD4V15's Avatar
    May 2011
    Virginia
    When I hit bumps the passenger side rear makes a couple 'popping' sounds. (sounds like passenger side, at least)
    Havent gotten around to looking (to cold)
    It started doing this maybe a month ago...
    Was wondering if anybody had any sugestions.
    Thanks,
    Eric
    *1997 gtp coupe
  2. #2 Re: Popping noise in rear?? HELP
    You live in Virgina and are saying too cold? Wuss, get under the car.
    It's likely a sway bar end link, spring, or strut mount.
  3. #3 Re: Popping noise in rear?? HELP
    SE Level Member pontiacgtp24's Avatar
    Jan 2012
    Michigan
    Link pins in these do go bad often. easy to check. get down and try to move it up and down at base of sway bar (at link).if it makes a noise...BINGO!!
  4. #4 Re: Popping noise in rear?? HELP
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    Check the lower control arm I went crazy looking for that same type of noise could not find any noise when up on a rack everything looked good finally checked with car on the ground the front bolt to the body had come loose.
  5. #5 Re: Popping noise in rear?? HELP
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    How many miles are on the car.
    Most likely the strut mounts. I had the same problem, popping/clunking noise when going over bumps.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. popping noise
    By ohagen383 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2011, 08:53 AM
  2. Loud Popping noise from rear end.
    By Iceman1983 in forum General Tech Discussion
    Last Post: 06-09-2011, 11:14 PM
  3. Nice popping noise
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 01-28-2011, 05:16 PM
  4. popping noise.
    By wlmrt6 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2010, 11:52 PM
  5. Popping noise from the rear
    By tjhgtp86 in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2010, 11:29 PM
