Thread: 04 GTP Mount Replacement Help
Results 1 to 3 of 3
  1. #1 04 GTP Mount Replacement Help
    Jan 2012
    Utah
    I replaced the engine of my 04 GTP about 20K ago and should have changed the mounts. Now, I've got some vibration/rattle problems that seem to be mount issues. Anyone have an idea of the difficulty/time required to replace the lower mounts and tranny mount? Is it a pretty straightforward process?
  2. #2 Re: 04 GTP Mount Replacement Help
    Donating User Odi's Avatar
    Chicago South Suburbs
    Its fairly easy, there was a writeup but for some reason it doesnt work anymore...
  3. #3 Re: 04 GTP Mount Replacement Help
    Apr 2011
    Athens, AL
    Remove the cover on that side and loosen the nuts on the mount. Remove the upper mounts. Use a 4x4 on the oil pan and support the engine. Remove the nuts and lift the engine enough to remove the mount. Put the wood block on the side you are working and make sure it spans to the edges of the pan. It will take about a half hour for each side.
  1. Engine Mount Replacement [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 06-09-2013, 01:24 AM
  2. What mount should I get first?
    By kyle91 in forum General Tech Discussion
    Last Post: 07-26-2011, 01:51 PM
  3. Multikit/Mount Kit to mount EQ?
    By iceman977th in forum Audio, Security & Visual Electronics
    Last Post: 03-25-2011, 01:59 AM
  4. Gxp engine mount replacement
    By tfro in forum 5.3L V8 (LS4)
    Last Post: 08-21-2009, 06:41 PM
