Thread: front end wobble
Results 1 to 4 of 4
  1. #1 front end wobble
    Dec 2011
    ohio
    Hello,
    I have a 2002 Grand Prix GTP SC. It has a front end wobble all the time, at slow speeds you can actually watch the front end move from side to side and then put on brakes and it feels like warped rotors. I put new rotors and brakes all around with out change. Tires have been rotated. On car lift no movement in wheel bearings. wheels seem to be running straight when idling on lift, but when put brakes on you can see brakes move like bent rotor. I am out of ideas. HELP.
    Newmod
  2. #2 Re: front end wobble
    If it wobbles all the time I'd be replacing some front end parts. Check out the lower control bushings and ball joint they are common wear spots on the front suspension.
  3. #3 Re: front end wobble
    check your tie rods as well, if they were bad you would get a side to side wobble. and slop in the steering wheel.
  4. #4 Re: front end wobble
    Dec 2011
    ohio
    Well, took the car into the shop, checked rotors, they were fine. Ended up being the tires. Tech said there was a 3mm buldge in one tire. New tires and alignment today.. Rides like a champ !!!!!
  1. Help, Death Wobble!
    By Brooks in forum Brakes/Suspension/Chassis
    Last Post: 04-13-2011, 05:48 AM
  2. Clunk/wobble?
    By JESSEGOTTA GP GT in forum Brakes/Suspension/Chassis
    Last Post: 08-20-2010, 07:27 PM
  3. Got myself some wobble and need help
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2010, 08:05 PM
  4. Just got grant rebuilt, front end wobble
    By SDGTP99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2010, 05:38 PM
  5. Front End Phantom Wobble
    By 02BlueGTP in forum Brakes/Suspension/Chassis
    Last Post: 03-25-2010, 11:04 AM
