Thread: Front GTP Brakes Touching Rotors
Results 1 to 13 of 13
  1. #1 Front GTP Brakes Touching Rotors
    Dec 2011
    Canada
    Are the brake pads supposed to be touching the rotors? Might be a stupid question but I read some posts that they only look like there touching but there "floating", but my front pads definitely look like they are touching. I just fixed my seized parking brake and now when I drive the car there are really high pitch squealing coming from the from wheels. I didn't hear this before I fixed the parking brake. Any suggestions? Thanks in advance.
  2. #2 Re: Front GTP Brakes Touching Rotors
    GTP Level Member tms8582's Avatar
    Washington Michigan
    If the noise arrived after working on the rear brakes my guess is that the shoes are still not releasing all the way and are rubbing just a little. If you jack the car back up and spin the wheel you should hear if they are making noise. As far as the front brake pads they are not supposed to touch unless your foot is on the brake pedal. There is not much space between the rotors and pads and it looks like they are touching. Again jack up the car and spin the wheel to find out.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: Front GTP Brakes Touching Rotors
    Dec 2011
    Canada
    I'm sure I will get a lot of negative replies for this but I cut out the parking brake shoes. I have never used parking brakes in my life other than on my manual cars. I don't know why I used it this time, but I did. The car is old, beat up, high mileage with many other problems. It's not a car you would pour $$ in babying. I just want it to run as long as it can, as cheap as it can. Money is an absolute factor right now in my life, and my decision to cut out the shoes. I'll take neg replies along with help, thanks.
  4. #4 Re: Front GTP Brakes Touching Rotors
    cutting the lines may have not released the parking brake all the way and it could still be rubbing.
  5. #5 Re: Front GTP Brakes Touching Rotors
    Dec 2011
    Canada
    I did not cut the lines, I literally cut the brake shoes in half and took them out. That's all I did. But how would the parking brake affect the front brakes?
  6. #6 Re: Front GTP Brakes Touching Rotors
    Do the front wheels spin easily with the car in the air? I had a 93 beretta that had the abs module go bad and the front brakes drug all the time i just replaced the master cylinder with a non abs one and all was fine after that.
  7. #7 Re: Front GTP Brakes Touching Rotors
    Dec 2011
    Canada
    Your methods of repair are questionable at best.
    I never said I wanted to repair it. I don't need them so I rather get rid of them then spend hundreds of dollars needlessly on a car that is not worth it. It's a matter of having lost a job at a very crucial point in life and having to balance priorities over having to "baby" a car like most of you do. It's unfortunate that most people do not have the ability to understand what it's like to have to wonder how your going to pay your bills every month, not which set of overpriced rims should I get. I need my car to move, not be able to look and act like a brand new car, or a show car.
    I understand some people come on these boards for advice to customize and upgrade which is great, but some people actually come here for regular "helpful" mechanical advice on repairs they "need" to make, try to remember that.
  8. #8 Re: Front GTP Brakes Touching Rotors
    Omaha, NE
    You probably have a warped rotor or two. Your methods of repair are questionable at best.
  9. #9 Re: Front GTP Brakes Touching Rotors
    Dec 2011
    Canada
    I will have to check that tomorrow morning, it is dark and freezing out right now. Thanks for the suggestion.
  10. #10 Re: Front GTP Brakes Touching Rotors
    Sep 2011
    MI
    If the noise is comming from the front it is more than likly 1 of 2 things:
    1)brakes have reached the squeal tab(also known as the indicater tab) - pretty much telling you you'll need front brakes soon
    2) There is a little "guard" that rides right by the rotor on the bottom inside of the rotor. Not really visable with the wheel on. sometimes ice or somthing can bend it just enough to have it rub on the rotor.
    What you did in the rear isn't going to cause any issues in the front. And lets face it. e-brakes are pretty much useless on auto cars. if you are in such a tight spot that you need it to stop the car, chances are you've hit whatever it was you were hoping to avoid before your foot gets halfway to the e-brake. most senarios go like this: ahh crap! hit brakes- brakes drop to the floor - crunch. see no time for e-brake. I live in upper michigan and most cables on 10 year old cars are seized from lack of use anyways.
  11. #11 Re: Front GTP Brakes Touching Rotors
    Dec 2011
    Canada
    Just checked, they don't really want to move in the air. I tried searching for a grand prix MC without abs and had no luck. Anybody know of one? Could I just get a ABS module from another GTP and install that, assuming that one is in working order?
  12. #12 Re: Front GTP Brakes Touching Rotors
    touching is the flaw of floating calipers.
    However, wheels should still spin, but consider you're turning the transmission at the same time.
    Its not your ABS or MC, they don't apply any force when the vehicle is off.
    Take the sliders out, clean out the hole, install with new brake grease.
    Also try to compress caliper, if this isn't possible the caliper may be seized.
    E-brake is needed for a safety.
    I'd pull the rear rotor to make sure nothing is scraping against the inner hat.
    Also, check dust shields.
    Sometimes they get bent and rub against the rotors.
  13. #13 Re: Front GTP Brakes Touching Rotors
    Dec 2011
    Canada
    Thanks, I will check that out.
  1. OEM Brakes or Drilled/Slotted Rotors For Winter?
    By extreme in forum Brakes/Suspension/Chassis
    Last Post: 10-16-2011, 07:48 PM
  2. O'Reillys Brakes and Rotors
    By quickster in forum Brakes/Suspension/Chassis
    Last Post: 03-31-2011, 11:45 PM
  3. Need brakes. Thinking about Eradispeed rotors.
    By charlie31603 in forum Brakes/Suspension/Chassis
    Last Post: 03-27-2011, 01:21 PM
  4. Replace Brakes and Rotors But still have a rubbing Noise.
    By rollin77 in forum Brakes/Suspension/Chassis
    Last Post: 11-24-2009, 02:02 AM
  5. Brakes and Rotors
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2009, 11:22 PM
