i had my friend at work take a took at my alighnment and it showed i had -2.0 camber on both fronts.. how is that possible if its all stock??
Worn suspension parts
Was the car aligned after the struts were installed?
do all the suspension parts look good? How are the ball joints and lca bushings?
Ball joints, bushings, rubber mount are probably worn and shot.
You didn't lower the car correct?
I'm around 1.8 out back and 1.6 out front.
Stock ride height.
