Thread: Need help quickly ASAP RIGHT MEOW
Results 1 to 19 of 19
  1. #1 Need help quickly ASAP RIGHT MEOW
    Donating Users lflylow's Avatar
    Yakima, WA
    I need to remove my steering knuckle so i can take it and the hub to a shop so they can remove a rounded bolt for me, now i have gotten the outer tie rod nut to the end of the bolt but when i turn it now it just turns the bolt how do i get this bolt to stop turning.
    2000 GTP, retro's, Debadged, 15% Tint, SD headers, TB HAI, EGR delete,
    Tuned By Reptile, WBS Perf. LCA's, GMPP rear sway bar Dorman front, Tinted tails.
  2. #2 Re: Need help quickly ASAP RIGHT MEOW
    grab the bottom with a pair of vise grips if you have already rounded it off then take the nut off with an 18mm wrench.
  3. #3 Re: Need help quickly ASAP RIGHT MEOW
    Yakima, WA
    i have already tried the craftsman version of those sockets didn't work
  4. #4 Re: Need help quickly ASAP RIGHT MEOW
    Yakima, WA
    the tie rod nut isnt rounded its just turning the bolt when i try to take it off.
  5. #5 Re: Need help quickly ASAP RIGHT MEOW
    the bottom of it should be like 10mm or 8mm so you can put a wrench on the tie rod stud and on the nut.
  6. #6 Re: Need help quickly ASAP RIGHT MEOW
    Grand Rapids, MI
    ifly, to get the bolt out of the hub, use this. Buy Irwin Expansion 5 Pc Set Pliers 394002 at Advance Auto Parts
    it's a bolt grip, it'll grab that bolt and take that sucker right out.
    as for the tie rod, get some vice grips and get a good grip on it and get that nut off.
  7. #7 Re: Need help quickly ASAP RIGHT MEOW
    Feb 2010
    TN
    Those things are worth double their weight in Gold
    Quote Originally Posted by brandonl2000 View Post
  8. #8 Re: Need help quickly ASAP RIGHT MEOW
    if nothing else you could cut the tie rod end off and just get a new one.
  9. #9 Re: Need help quickly ASAP RIGHT MEOW
    Pennsylvania
    JB Weld.
  10. #10 Re: Need help quickly ASAP RIGHT MEOW
    Yakima, WA
    im gonna cut it off and get a new one
  11. #11 Re: Need help quickly ASAP RIGHT MEOW
    tighten it back up and start over, (not kidding) sometimes it works, some times it dont. after you get the nut off whack it with a hammer on the side to pop it loose from the knuckle.
  12. #12 Re: Need help quickly ASAP RIGHT MEOW
    impact.
    Mine spin, unless i use impact.
  13. #13 Re: Need help quickly ASAP RIGHT MEOW
    Yakima, WA
    for the tie rod bolt I'm gonna try what this guy did 1997-2003 Grand Prix Outer Tie Rod End Replacement - Automotive Forums .com Car Chat
    I'm also gonna try those sockets again with the axle out of the way its a lot better angle.
  14. #14 Re: Need help quickly ASAP RIGHT MEOW
    If you can cut the tie rod, then likely you can cut the head off the hub bolt that you are trying to get off. Just saying, maybe the answer to your problem is easier than trying to get the tie rod end off.
  15. #15 Re: Need help quickly ASAP RIGHT MEOW
    Yakima, WA
    yea never done an axle before. but i did get it to go, now apparently i some how fvcked the threads up on the ball joint gonna try to fix it tomorrow.
  16. #16 Re: Need help quickly ASAP RIGHT MEOW
    Yakima, WA
    OK so I have now gotten the hub off the knuckle and I'm at the point where I'm trying to put the drivers side axle into the transmission and know matter what I can't get it to slide into the transmission.
  17. #17 Re: Need help quickly ASAP RIGHT MEOW
    SWPA
    If its like any other FWD axle with a circlip it needs to be POPPED into place. It wont just slide into place.
  18. #18 Re: Need help quickly ASAP RIGHT MEOW
    Grand Rapids, MI
    you sure a mechanic wouldn't be of use to you?? bolts and threads aren't agreeing with you too well...
  19. #19 Re: Need help quickly ASAP RIGHT MEOW
    Yakima, WA
    fvck that, live, learn, buy performance parts for the sh!t you break.
  1. Alright Meow
    By fubar569 in forum Introductions/Noob Questions
    Last Post: 07-08-2011, 10:44 AM
  2. Some one buy me this right meow
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 01-30-2011, 09:12 PM
  3. 2003 is not getting up to speed quickly
    By BUCKEYE in forum Introductions/Noob Questions
    Last Post: 08-10-2009, 12:32 PM
  4. O2 Sensor Removal-Help Quickly
    By TCO in forum General Tech Discussion
    Last Post: 11-08-2008, 08:36 PM
  5. So she was bathed... but QUICKLY haha
    By drunknmunky in forum Visual/Body Modifications
    Last Post: 07-12-2008, 07:58 PM
