running ssc and gr2's?
and the ssc dont seem to have a high rate so do they ride ok?
they are alright. i think for how they ride they should be lower, but that is just me coming from an eibach car. a friend of mine has SSC on his car and they do just fine.
Time to get the thread back on track
So i just ordered a dorman front sway bar..now what?
i want to run poly bushings, where and which ones should i go with?
next will be the rear sway bar
should i just go with a gmpp bar and be done with it?
Moog for 1.26".
is that for our car with 1.26" sway bar?
Go under the listing for your car.
You'll see different sizes.
Pick the 1.26" one.
never could find the poly bushings but i moved on
Started pricing struts, springs, top mounts
now i need to find the pogo things, not exactly sure where and what those are
and i've seen boots and bump stops do i need to get those separately or does those come with the struts?
I just bought everything for my setup. The anti-pogo washers you can get straight from any GM dealer the part number is 10203412 listed as a "retainer". Typically the boots and bump stops come as a package. I ordered the monroe ones the PN is 63622 for the front and 63973 for the rears
while im in korea i piecing together my suspension parts. i have the GMPP sway bars and tower braces, DR tower brace brackets, and lowering springs. im ordering 97-03 LCA's so i can mount the front sway. trailing arms are next. ill put them one all at once so she feels new.
For poly bushings, I'd check Energy Suspension. I used the GMPP bar and all the info with pictures of boxes etc is in my Regal thread.
Little Update
Since i let this thread die
I got the front sway bar in and new tie rods on. Went to a new yard today and picked up a gm stb w/hareware now i need to find the brackets or drill the holes.
Anybody know what size bit/hole i need?
