Thread: 2001 suspension 1" lift for rear???
Results 1 to 4 of 4
  1. #1 2001 suspension 1" lift for rear???
    monroe,wi
    Ok i have a 2001 GTP with a some heavy subs in it and the rear sags like a mofo.. I know w-body has springs that lift it an inch or so to accommodate for such a thing but is there anyone else out there that makes strut blocks or spacers for the rear of our cars?? 130 for springs inst terrible just wondering if there is anything cheaper??? I remember a while back some where in forum land there was someone saying that the springs w-body store has was from another vehicle?? I cant seem to find it now any help would be much appreciated
  2. #2 Re: 2001 suspension 1" lift for rear???
    Portland Oregon
    Rear springs from an olds intrigue will fit and give the rear a bit of lift.
  3. #3 Re: 2001 suspension 1" lift for rear???
    monroe,wi
    Ok thanks ill check into that. I have About 200lbs of subs and box in my truck so that hopefully will work well... Any special year or model???
  4. #4 Re: 2001 suspension 1" lift for rear???
    Dec 2011
    Southern Wisconsin
    Older post but I am from Monroe too
    You can use some coil spring helpers to give it a more stout stance. Inexpensive, easy to install.
    They would go in between the individual coils of the spring and keep them from compressing. Should help out if it is just sagging from extra weight. If they are sagging from being worn out this may not be the best option.
  1. 02 Air Lift Suspension
    By Hawkins97 in forum Brakes/Suspension/Chassis
    Last Post: 07-25-2010, 11:13 PM
  2. "CLUNK" suspension noise when i step on it?
    By whitelightning in forum General Tech Discussion
    Last Post: 05-29-2010, 05:51 PM
  3. rear suspension, 04+
    By sportred04 in forum General Tech Discussion
    Last Post: 03-09-2010, 07:20 PM
  4. Rear suspension help
    By thirdgenfcarnut in forum Brakes/Suspension/Chassis
    Last Post: 08-16-2009, 04:25 PM
