Heres the suspension setup so far:
Bilstein HD's.
Vogltand springs spring rates: 200/140
Dorman front sway bar, 33 mm solid.
ADDCO rear sway bar, 22 mm solid.
GMPP trailing arms.
Things that dont matter:
ZZP STB's, poly sway bar bushings and front end links. Moog rear links.
Its not comfort I'm concerned with at all.
I wouldn't care if it the car beats me up all the time.
Yes, have been in cars that do that for extended periods of time and driven them.
Car is already a little harsh on the bumps.
ZZP ships their coilovers with 350/275 spring rates.
I think this will be a little high for maintaining traction on the rough roads that we have around here.
I'm thinking a nicer compromise would be 275/200.
Similar increase as going from stock (143/120) to the vogtlands.
Just need to talk to more people running spring rates that high.
