Thread: Right rear brake leak
Results 1 to 5 of 5
  1. #1 Right rear brake leak
    Sep 2011
    Ontario, Canada
    My 2004 GP GT2 had its low break fluid light came on earlier this week when I was leaving work. Looked at the ground underneath my car and noticed a small puddle inward from the right rear wheel. Had the chance to take the wheel off and look around this afternoon. It appears the seal behind the piston is leaking (pics available here: Photo Album - Imgur). It looks pretty dirty/corroded under this seal.
    Is it possible that replacing the seal will fix my problem, or will I need to replace the caliper?
  2. #2 Re: Right rear brake leak
    I'd be a lot easier to just replace the caliper but you could replace the seal.
  3. #3 Re: Right rear brake leak
    Sep 2011
    Ontario, Canada
    Is there normally some brake fluid contained within that seal, or is it just supposed to protect from dirt and corrosion?
  4. #4 Re: Right rear brake leak
    Is that the boot that holds the piston in? I can't really tell from the pics.
  5. #5 Re: Right rear brake leak
    Sep 2011
    Ontario, Canada
    We're looking at the back of the caliper where the torsion spring for the parking brake is. The attachment has a top-down view of the caliper.
    Right rear brake leak Attached Images
  1. Brake Fluid Leak
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2011, 10:47 AM
  2. rear brake leak
    By 04silverprix in forum Brakes/Suspension/Chassis
    Last Post: 07-28-2011, 11:20 PM
  3. oil leak from rear
    By twol8uluz in forum General Tech Discussion
    Last Post: 04-04-2011, 04:36 AM
  4. Leak right rear wheel.
    By itsjay in forum Brakes/Suspension/Chassis
    Last Post: 10-28-2009, 11:11 PM
  5. 2002 Grand Prix - Right Rear Brake Leak
    By johngandersonjr in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2008, 09:43 PM
