Thread: Crunch in steering wheel '04 Grand Prix
Results 1 to 6 of 6
  1. #1 Crunch in steering wheel '04 Grand Prix
    Nov 2011
    West Virginia
    I have a strong "crunch" in the steering wheel of my '04 Grand Prix. This happens at low speed turns and when sitting still. Mostly when turning right. You can hear it slightly, but primarily feel it in the steering wheel. I checked the front end and found slight play in the wheel bearings, so I replaced both hub assemblies and this did not fix the problem. I have read issues about the intermediate shaft but don't want to keep putting money into stuff that is not gonna fix the problem. Any ideas where to start?
  2. #2 Re: Crunch in steering wheel '04 Grand Prix
    SE Level Member Galaxy04CompG's Avatar
    Oct 2011
    Michigan
    I am hearing the same problem. The steering is a bit creaky? I don't know if the Magnasteer makes it sounds any different? Just sounds like its too tight or something when I slowly turn the wheel?
    2009 Liquid Red G8 Premium V6 - 40K (Wife's)
    2004 Galaxy Silver Comp G 49K
    1999 Grand Prix Arctic White Coupe 139k-$3800 SOLD
    2001 Grand Prix GT Arctic White 92K-SOLD
  3. #3 Re: Crunch in steering wheel '04 Grand Prix
    it could be a few things, like the intermediate shaft needs to be lubed, or the ball joints, lca, tie rods.
    your going to need to go over the whole front ends parts and narrow it down to where the sounds are coming from.
    sounds like the intermediate shaft tho.
    theres a write up here somewhere for it.
  4. #4 Re: Crunch in steering wheel '04 Grand Prix
    Oct 2011
    Toledo, OH
    DO NOT LUBE THE ISS. That is just a band-aid.
    It's coming from the Intermediate Steering Shaft. It's a problem with all GM cars with that shaft.
    Google the TSB "01-02-32-001O"
    7"
  5. #5 Re: Crunch in steering wheel '04 Grand Prix
    Quote Originally Posted by industrialfish View Post
    i would rather lube it every year vs replacing it. like it matters, its not like its going to fall apart on you. all it is, is the slip joint not sliding well anymore.
    i just took out a steering column on a 97 regal, it had a very small amount of grease on it, but looked like it was new.
  6. #6 Re: Crunch in steering wheel '04 Grand Prix
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Good information. Thanks for the tip. I bookmarked that bulletin.
  1. 2006 Grand Prix GT Vibration in steering wheel
    By 04montess in forum Brakes/Suspension/Chassis
    Last Post: 09-12-2010, 03:58 PM
  2. Need 4 wheel rims for 02 grand prix
    By dkitt20 in forum Tires & Wheels
    Last Post: 12-27-2008, 08:28 AM
