Thread: Brake Pads Clunk
Results 1 to 3 of 3
  1. #1 Brake Pads Clunk
    Sep 2011
    Michigan
    Any ideas what would cause the front brake pads to clunk in reverse, and only once after going from forward to reverse? The front pads and rotors are new and the vehicle only has 35K on the clock. I'm not sure where to start. Also, the calipers are tight, just checked. Thanks for the advice
  2. #2 Re: Brake Pads Clunk
    Omaha, NE
    Triple check the calipers.
    Happened in my honda, I ended up puncturing the brake line, and had no brakes the rest of that day.
  3. #3 Re: Brake Pads Clunk
    you sure its the brakes?
    Id think a motor mount issue with how it only clunks once everytime you switch from D to R
  1. park brake pads?
    By 1BlwnGTP in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2010, 07:29 PM
  2. Brake Pads and rotors
    By packerfanjc in forum General Tech Discussion
    Last Post: 01-20-2010, 09:49 PM
  3. recommend brake pads
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 08:52 PM
  4. Brake pads for d/s rotors
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 03:24 PM
