Thread: trick to getting HP ps line on rack?
Results 1 to 4 of 4
  1. #1 trick to getting HP ps line on rack?
    Florida
    im in my swap and i have the 98 Z's L36 and high pressure power steering line. im trying to get it screwed into the rack.
    the rack is my original 96 Z34 and the l36 and HP line came out of the 98 Z34
  2. #2 Re: trick to getting HP ps line on rack?
    Florida
    here is a pic from autozone's website they look the same at where the HP an LP lines go in... is there any chance they changed the threads? according to the description,they are: the same inlet and outlet sizes in: 18mmx1.5 and out: 16mmx1.5
  3. #3 Re: trick to getting HP ps line on rack?
    PA
    Not sure if they changed threads or not. But I know those can be a pain to get in. You have to have them lined up just perfectly. Try moving the line itself around. And I've also found that you need to make sure the line is not pushed in too far. I will push it in all the way, then pull it back out a little bit and wiggle it around with one hand while I screw the threads in with the other hand.
    2001 GSE
  4. #4 Re: trick to getting HP ps line on rack?
    Florida
    ah!!! :lightbulb: i was pushing the line in all the way while turning! you daman! will try it tomorrow when i have access to those line wrench's...
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. trick for gaskets....
    By Z34Phoenix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2011, 12:55 PM
  3. Replace Magnasteer Rack with Regular Rack?
    By Smoker324 in forum General Tech Discussion
    Last Post: 06-29-2010, 09:11 PM
  4. I'm in Detroit, TRICK
    By MizzBecca in forum Midwest
    Last Post: 04-07-2010, 08:51 AM
  5. 04+ mph/kmph Trick??
    By offroadfury6 in forum General Tech Discussion
    Last Post: 08-08-2009, 06:20 PM
