Thread: fbody brake upgrade
Results 1 to 14 of 14
  1. #1 fbody brake upgrade
    chicago
    i know i inquired about this before, but that was awhile back. there might be some new updated stuff that i missed out on. anyway i saw zzp selling fbody bolts and sleeves kit. i thought about going that route, but remembered reading my old post that someone recommended not to use the bolt sleeves. my question is i'm taking to the machine shop and have them drill and tap out. can someone high lite out where it should be tap out and what's the bolt size it suppose to tap to.
  2. #2 Re: fbody brake upgrade
    Donating Users GR8racingfool's Avatar
    Wichita, KS
    Working on it for ya.
    ~F~
  3. #3 Re: fbody brake upgrade
    Wichita, KS
    Here ya go:
    Be sure when you install the caliper mounting bolts you use Loctite on them and be sure to torque them correctly and drive worry free. I even reused my old OEM caliper bolts with NO Loctite and never ever had them loosen up on me, and I have had my calipers on and off many different times since the original installment.
    TOO, waaaaaaaaaaaaay too many people have used the shim/sleeve method and had their caliper bolts come loose, or completely out. 3 locals here have had this happen, and the caliper gets chewed up, as well as the rim every time. I am so strongly against using the shim/sleeve method. Its just not a safe proven method.
    ~F~
  4. #4 Re: fbody brake upgrade
    Barksdale AFB, LA
    When I replaced my front rotors I also used the factory bolts and didn't add loctite. I recently checked the torque on them and they're still just right. I think the bolts still retain some factory loctite so they don't back out.
    2009 Subaru Impreza WRX STI
  5. #5 Re: fbody brake upgrade
    Jul 2008
    Fishkill, NY
    You need to have the caliper mounting bracket bolt holes tapped to 14mmx2.0. On the FBody brakes they use a 12 mm bolt and the GP uses a 14mm, so doing this allows you to use the stock size bolt with your new caliper brackets. My shop charged me 43 bucks to do all 4 holes.
  6. #6 Re: fbody brake upgrade
    Wichita, KS
    Drill bit and tap ran me $18.28 and I only use them for this mod. They have their own little special case in my tool box.
    Add in a drill press and a drill vice and its cake to drill and tap them.
    ~F~
  7. #7 Re: fbody brake upgrade
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    Do as the Farnsworth say, and only as the Farnsworth say.
  8. #8 Re: fbody brake upgrade
    Wichita, KS
    Just some advice from personal experience I am sharing.
    We were on our way to the Branson Meet, waaaaaay out in Eastern Kansas where there was nothing but high way, and one of the guys in our group needed to pull over cause something didn't sound right and feel right. Right front caliper was grinding on his rim. As usual the top bolt fell out and hen he hit his brake the caliper pivoted on the bottom bolt, and the rim stopped the caliper form going any further as he was driving, and as he stopped. Chewed the caliper up pretty good, as well as his rim.
    LUCKY, the bolt did not fall out all the way, it was bent, and barely holding on, so we were able to get it back in there on the side of the road to get him going again, and he later fixed it when we got to Branson. It would of really-really sucked if he had lost the bolt completely.
    Food for thought....
    Every caliper kit I redo and resell has this already done to it when it leaves my hands.
    The only reason why I think people feel the need to do the shim/sleeve mod is so after they remove the calipers for what ever reason (demod?) they can still be used on a F-body car.
    Brakes are pretty important...you kinda need them, epically the front ones...I don't think its worth the risk to use the shim/sleeve mod with these as it allows too much play in the caliper bracket, and the more you use your brakes, the more play it gets till one or both of the bolts loosen up and thats all she wrote. Even had one local use RED non-removable loctite and grade 8 bolts and hes a pretty strong guy and he torqued them down hard, and know what...short time later, one of his fell out and trashed his nicely powder coated caliper. But he caught it in time, so the damage was not too bad.
    I think ZZP is just trying to make a buck and not really thinking this one through. But I'll let them open that can of worms, cause they will just tell the customers who loose a caliper bolt, "they must of not got them tight enough, sorry".
    ~F~
  9. #9 Re: fbody brake upgrade
    Greensburg, PA
    Hey this is kinda off topic of I've got a grinding noise when i turn my wheel completely left or right. I do have the f-body upgrade and longer ZZP SS lines. I don't have the pad retainers in yet could that be the problem or i read somewhere a shield that could be rubbing can't remember if that delt with the F-body front or GXP front?
    Mods:3.4 pulley + recommended mods/ F-Body Front & rear GXP Calipers/ GMPP handling upgrade kit + otto strut brace/ SSC Gen 1 Springs on GR-2 struts/ Verde 5 18x8 Rims
  10. #10 Re: fbody brake upgrade
    SE Level Member 2kblackgtp's Avatar
    Aug 2008
    Scotch Plains, NJ
    dumb question but when i got my fbody calipers, there was only one pad retainer to a caliper. is there supposed to be one on each side of the caliper aka 4 total?
  11. #11 Re: fbody brake upgrade
    Greensburg, PA
    Id have to say one per side. Thats what I got too and Im not sure how a second pad retainer per side, could fit
  12. #12 Re: fbody brake upgrade
    Wichita, KS
    There should be two pad guides on each end of the pads in the calipers that the pad ends slide on. There is one "retainer" so to say, on the very top middle that keeps the pads from chattering. All install from the inside of the caliper body. Those are the only clips, guides, retainers on the f-body calipers.
    ~F~
  1. Rear brake upgrade question
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 09-16-2009, 03:15 AM
  2. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
  3. longer SS brake lines (fbody brakes)
    By UR LOSN in forum Brakes/Suspension/Chassis
    Last Post: 03-30-2008, 02:38 PM
