Thread: Aftermarket Camber Bolt Removal
Results 1 to 9 of 9
  1. #1 Aftermarket Camber Bolt Removal
    Willoughby, Ohio
    did a search but did find much help. i currently have a 99 GT rust bucket with 4 AGX struts and eibach springs. i want to put these on my non rusted GTP. i got the stock upper bolts on the shocks/struts out with my impact wrench no problem. i cant seem to get the bottom aftermarket cam bolts i had a local shop install out. the head is like an oblonged hex shape so im wondering is there a tool for this and what is it called? just looking if anyone has any tricks or hints, thanks GPF
  2. #2 Re: Aftermarket Camber Bolt Removal
    there is no trick.... You just have to get the nut off the one end of the bolt, then tap the bolt out. You still hold a wrench on the head of the bolt like normal while removing the nut. Then thread the nut back on by hand and tap it with a hammer or if you've got a pin punch that would work better......
    Those camber bolts were used because the new struts didn't come with oval holes in them for camber adjustment...
    Snorlax strikes again.
  3. #3 Re: Aftermarket Camber Bolt Removal
    Willoughby, Ohio
    ok i see, ill give it a shot and keep workin it, thanks
  4. #4 Re: Aftermarket Camber Bolt Removal
    HUDSON
    Air chisel with a large blunt end on the strut bolt nut end, it will drive it right through
  5. #5 Re: Aftermarket Camber Bolt Removal
    Willoughby, Ohio
    well i got 3 shock/coil combos out im down to 1 stoopid bolt and im good to go
  6. #6 Re: Aftermarket Camber Bolt Removal
    Willoughby, Ohio
    down to one stock bolt and nut, impact wont make it move for some reason
  7. #7 Re: Aftermarket Camber Bolt Removal
    Willoughby, Ohio
    used my nice heat gun and it was enough to loosen it....wow what a b***h but im happy again
  8. #8 Re: Aftermarket Camber Bolt Removal
    So end result you got the camber bolts eh???
  9. #9 Re: Aftermarket Camber Bolt Removal
    Willoughby, Ohio
    yes heat was the trick, good suspension is off the rusty GT and on the nice GTP, now just gotta put old GTP suspension on GT for winter and im good to go, thanks guys
  1. Dropped my car...camber is off.
    By Ballin00gtp in forum Brakes/Suspension/Chassis
    Last Post: 11-28-2010, 10:21 PM
  2. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  3. Neg Camber on my 08 GP
    By 2008 Grand Prix in forum Brakes/Suspension/Chassis
    Last Post: 08-02-2010, 08:26 PM
  4. Camber
    By SlowM90 in forum Tires & Wheels
    Last Post: 05-14-2009, 06:01 PM
  5. Pulley bolt removal
    By Zinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2009, 07:54 PM
