Thread: Brake Fluid Leak
Results 1 to 6 of 6
  1. #1 Brake Fluid Leak
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I'm about to start diagnosing a brake fluid leak on a buddies car, and I'm just curious if there are common spots there cars like to leak brake fluid?
  2. #2 Re: Brake Fluid Leak
    Portland Oregon
    You tell me, what part of the car does it seem to be coming from? Could be anything without knowing where it's coming from. Split brake hose on one of the corners, any one of the numerous fittings on the hard lines, rusted through hard line, ABS module, master cylinder.
  3. #3 Re: Brake Fluid Leak
    Quote Originally Posted by OH4CompG View Post
    No leaks seem to be coming from the master cylinder, I was just curious if there are any trouble spots. I haven't gotten under and looked at it, because it's been terrible weather and it's parked outside in the alley.
  4. #4 Re: Brake Fluid Leak
    Waukesha, WI
    the right pas line is usually the first to blow, it sits in a crappy spot that gets crap kicked at it
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  5. #5 Re: Brake Fluid Leak
    check them from front to back.... There is no exact area that brake lines rust or deteriorate....
    Snorlax strikes again.
  6. #6 Re: Brake Fluid Leak
    What kinda car does your buddy have..lol
    Easiest way to find it. Fill mc. pump the hell out of brakes and look for drippin
  1. Trans Fluid Leak???
    By ill12will8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2010, 07:58 PM
  2. brake fluid
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2009, 06:51 PM
  3. Brake Fluid
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 09:27 PM
  4. Power Steering fluid leak--Where?
    By jokyfo in forum General Tech Discussion
    Last Post: 10-06-2008, 05:17 AM
  5. Power Steering fluid leak
    Last Post: 09-28-2008, 11:24 PM
