Thread: 02 GT Steering wheel shake
Results 1 to 10 of 10
  1. #1 02 GT Steering wheel shake
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    When around 20-40mph the steering wheel will shake left and right on its own about an inch or so if I'm not holding on along with the car pulling left hard. but around 50-80 little to none steering wheel shake but just vibrations from what I believe to be bad tries. Not sure what the cause could be I'm thinking CV shafts, tie rod ends, tires. Anyone have any input or idea's?
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: 02 GT Steering wheel shake
    Ohio
    probably axles
  3. #3 Re: 02 GT Steering wheel shake
    Apr 2012
    Dayton, OH
    Wouldn't the shaking get worse at higher speed if it was? or not necessarily?
    2012 F150 STX
  4. #4 Re: 02 GT Steering wheel shake
    Apr 2012
    Dayton, OH
    Jacked up the front and Right Front wheel has a little play when I grab by the top and bottom and move back and forth. It like clicks I guess is the sound. I think the previous owner had replaced the RF wheel hub once before, if i remember right. I still down think that would cause the whole front end to go side to side at low speed tho.
    2012 F150 STX
  5. #5 Re: 02 GT Steering wheel shake
    sounds like you found a bad hub.
  6. #6 Re: 02 GT Steering wheel shake
    Apr 2012
    Dayton, OH
    Well crap, its this right? I'm found one on rock auto for like 86$ I plan on putting in after my new tires.
    2012 F150 STX
  7. #7 Re: 02 GT Steering wheel shake
    thats what i used, good old timken.
  8. #8 Re: 02 GT Steering wheel shake
    Apr 2012
    Dayton, OH
    Thanks! Now to replace this stupid thing.
    Get use to it lol. Having a Wbody you'll probably have to replace a few of them in your time.
    04 Comp G.
  10. #10 Re: 02 GT Steering wheel shake
    Apr 2012
    Dayton, OH
    Replaced the bearing with the problem still there. Solved it by stealing the two front tries off our other GP, and after examining the LF tire it had so many bulges and one of the belts in it shifted or someting. Thanks everyone!
    2012 F150 STX
  1. Bad Steering Wheel Shake On Downhill Braking
    By BeachVette6 in forum Brakes/Suspension/Chassis
    Last Post: 08-09-2010, 01:43 PM
  2. shake in steering wheel
    By johnniep in forum General Tech Discussion
    Last Post: 04-05-2010, 08:04 PM
  3. Wheel shake
    By Mikey in forum General Tech Discussion
    Last Post: 03-18-2010, 07:46 AM
  4. steering wheel
    By Dawings33 in forum 04+ Specifics
    Last Post: 06-26-2009, 02:37 AM
