Thread: Brake installation tips
Results 1 to 8 of 8
  1. #1 Brake installation tips
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I need to install new rotors and pads all around my 01 gtp. Ive got the brake silicon, and will buy new clips.. (i forget what there called). I also will clean out the calipers and other areas before installation. Any other tips? Im not doing this on my own, the person I am doing it with has installed rotors before, but I would like to see if I am over looking anything.
    Thanks for the tips!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: Brake installation tips
    GT Level Member beastin1's Avatar
    south elgin il.
    hey so tell me what happened... i gotta do my rear rotors and pads this weekend, and I'm wondering if a normal c-clamp will retract the cylinders...reason i ask is because on my 88 regal you need a special tool that turns them as they retract...
    2002 Galaxy Silver 4dr. GTP...supercharger heaven.
    IM ON IT!!!!!!
  3. #3 Re: Brake installation tips
    Saraland Alabama
    make sure and spray the rotors with brake clean before putting the pads on (they have a coating on them that will clog the pads)
  4. #4 Re: Brake installation tips
    south elgin il.
    Quote Originally Posted by archemedes View Post
    cool....thanks for the tip
    IM ON IT!!!!!!
  5. #5 Re: Brake installation tips
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Quote Originally Posted by beastin1 View Post
    A normal C-clamp will work just fine.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  6. #6 Re: Brake installation tips
    south elgin il.
    Quote Originally Posted by Warhellride View Post
    that's great news friend, thanks
    IM ON IT!!!!!!
  7. #7 Re: Brake installation tips
    GTP Level Member David99GTP's Avatar
    Florida
    My Lumina had those calipers. I hated using that little tool to turn the caliper as you compressed it. I dont think GM uses those calipers anymore, they were garbage. I replaced mine very often due to failure on the Lumina and was able to be part of a class action suit against GM for crappy calipers. I only was reimbursed 50 bucks though
    Anyway No need for that tool with our calipers.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  8. #8 Re: Brake installation tips
    south elgin il.
    Quote Originally Posted by David99GTP View Post
    yea thats great news,as i currently have my rotors and pads on the way from zzp.... and thank goodness they discontinued those calipers, they sucked....tell me did you know they needed to be turned to retract, or did you destroy a c-clamp or two like i did???
    IM ON IT!!!!!!
  1. Tweeter Installation
    By Burgundyman in forum Audio, Security & Visual Electronics
    Last Post: 08-13-2008, 12:37 AM
  2. HV3 Installation
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-18-2008, 09:37 PM
  3. Car Alarm Installation...
    By Guitarist575 in forum General Tech Discussion
    Last Post: 07-06-2008, 10:50 PM
  4. KVR big brake kit
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2008, 07:00 PM
  5. LS1 brake question
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2008, 12:14 PM
