Thread: Dorman Fornt Sway Bar Squeaks
Results 1 to 2 of 2
  1. #1 Dorman Fornt Sway Bar Squeaks
    Cliffside Park, NJ
    A Dorman Front Stabilizer Bar (927-100) was installed using all the included links and bushing. The center two bushing were lubricated. A month later it is squeaking like mad. (Until then there was only a rare clunking sound.) I contacted Dorman and was told to spray the end links with lithium grease. Unfortunately, this did nothing to reduce the squeaking.
    What should I try now?
    Thanks for the help,
    Joe
    1998 GTP
  2. #2 Re: Dorman Fornt Sway Bar Squeaks
    Joe,
    Likely it's becaue the oil didn't pentrate into the part that's squeaking.
    Take a look at what I did here and you'll see the best way to stop a squeak of this type.
    http://www.grandprixforums.net/sway-rage-52096.html
  1. Dorman Intake
    By GMFI in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2009, 01:11 AM
  2. squeaks over every bump
    By twoleos617 in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2009, 10:39 PM
  3. Power steering wheel squeaks
    By Viper in forum General Tech Discussion
    Last Post: 01-17-2009, 01:33 PM
  4. Front ends squeaks when steering...
    By brycemassey in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 06:15 PM
