Can you guy tell me which way the lines are route coming out of the steering pump. with variable rack.
thanks guys
thanks guys
High pressure comes out of the pump loops up then goes down to the sub frame then to the top hole in the rack. Return line just goes right to the sub frame then to the rack.
Anyone else??
Nick, sounds about right. I removed the lines to replace them with flexible hoses as I switched to a variable rack and they are bent-route differently.. Now I can't remember which way they go.. I believe they put the fittings on the wrong ends. GRRRR
