Thread: rear tires tilt in at top?
Results 1 to 13 of 13
  1. #1 rear tires tilt in at top?
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Leaving work today i noticed the back tires on my 03 GT were leaning in at the top a little bit. The car had new struts about a year ago and drives smooth and straight at 85mph down the interstate. There is probably 100 lbs or less of misc tools and stuff in the trunk.
    Is this normal or is it just my imagination?
    Thanks in advance for your replies!
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  2. #2 Re: rear tires tilt in at top?
    SE Level Member cannon's Avatar
    Jul 2010
    Benson, MN
    yes, Its factory camber. Helps with handling when you are taking corners and stuff
  3. #3 Re: rear tires tilt in at top?
    and wears your tires out WOOOOOOOO.
  4. #4 Re: rear tires tilt in at top?
    Nov 2009
    A little late
    Quote Originally Posted by cannon View Post
    Thanks for the quick reply!!
    I was really scratching my head, I parked in a different spot today, straight out the door and down a few steps.
  5. #5 Re: rear tires tilt in at top?
    SWPA
    This. I had some nice negative camber on my Stealth. Outside of the tires look brand new, inside is bald as bar whore's puss.
  6. #6 Re: rear tires tilt in at top?
    define nice.
    I'm at 1.6 or so out front and 1.8 in the rear last time I had it aligned... Needs another one though.
  7. #7 Re: rear tires tilt in at top?
    SWPA
    This isn't the best pic, but if you look at the snow on the rear wheel it gives you the idea of the camber.
  8. #8 Re: rear tires tilt in at top?
    damn....
  9. #9 Re: rear tires tilt in at top?
    SWPA
    She handles like a champ though. Had a cruise through some mountain roads a few years back with a bunch of other 3000GT/Stealths. The guy who was following me told me afterward that my car stuck to the road like glue and for the longest time he though my brake lights went out, I just simply wasn't using them.
  10. #10 Re: rear tires tilt in at top?
    lol
    LOL!
    camber that is around -3.0* or less WILL NOT ACCELERATE TIRE WEAR UNLESS YOU DO NOT GET AN ALIGNMENT AND FIX THE TOE SETTINGS.
    im running 2* all around right now. my tires are perfect. if you think otherwise you clearly have no idea what alignment should and should not do for a car. the lower you go, WITHOUT FIXING THE ALIGNMENT, the camber will INCREASE NATURALLY. that means if you have a butt load of weight in the trunk you are lowering the car naturally and camber is increasing because THAT IS HOW SUSPENSIONS WORK.
  11. #11 Re: rear tires tilt in at top?
    Nov 2009
    A little late
    So are we agreed that some is normal?
  12. #12 Re: rear tires tilt in at top?
    yes, the stock specs are around .7-1.5* of negative camber. if you put more weight in your trunk you will increase that.
    therefore: it's normal.
  13. #13 Re: rear tires tilt in at top?
    Nov 2009
    A little late
    Thanks Bio, now its time to watch the BADGERS!!!!
  1. Gxp rear tires
    By warren13 in forum Tires & Wheels
    Last Post: 11-18-2010, 12:38 AM
  2. Short in Tilt Column? Occasional No Start
    By randye in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2010, 02:14 PM
  3. new pics!! new rim/tires/rear led lights.
    By tmackster in forum Visual/Body Modifications
    Last Post: 10-18-2009, 12:25 AM
  4. Possible short in tilt column = no start?
    By randye in forum General Tech Discussion
    Last Post: 08-12-2009, 03:13 PM
