Thread: Getting really Angry over these brakes??
Results 1 to 20 of 21
  1. #1 Getting really Angry over these brakes??
    GT Level Member dengnath's Avatar
    I replaced my brakes about 5 months ago.... pads and rotors. 3 weeks ago they started making the most god aweful screeching noise when i stepped on the brakes. I know for a fact its coming from the front, so i decided instead of sticking with ceramic pads i would go ahead and put regular semi-met brakes on..... that worked for about a week of no squeeling, but today the squeeling started to come back. Any ideas here guys?
    my father keeps telling me its brake dust .... but it is so loud and happens about every 4th time i step on the brakes.
  2. #2 Re: Getting really Angry over these brakes??
    GT Level Member jmoore4294's Avatar
    Did you grease the back of the pads where it contacts the piston?
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  3. #3 Re: Getting really Angry over these brakes??
    How would that create a high pitched squeal that's constant while on the brakes? Not being a smartass I'm just confused ?
  4. #4 Re: Getting really Angry over these brakes??
    squealing is usually due to a vibration, so greasing the back of the pad, and the caliper slider bolts may help, also did you cut the rotors? that could help too.
  5. #5 Re: Getting really Angry over these brakes??
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    I had that issue with my girlfriend's old car. The rotors just needed to be turned. You could hear it squealing half a mile away it seemed.
    2009 G8 GT #1311 of 1949:CTS-V front/Camaro rear brakes, Solo Performance axle back exhaust
    2006 GP GXP: ZZP catback, k&n intake, retrofit headlights, cts-v brakes
    2007 Escalade ESV:family hauler
  6. #6 Re: Getting really Angry over these brakes??
    What do you mean turned?
  7. #7 Re: Getting really Angry over these brakes??
    he means cut the rotors, turn them is the term used, as they go on a metal lathe, and get turned.
  8. #8 Re: Getting really Angry over these brakes??
    Apr 2008
    Rockport, ME
    Quote Originally Posted by dengnath View Post
    Taking them to a machine shop to have the surface turned meaning cut. It makes sure the braking surface is level and not warped.
    scottydogs you beat me to it!
  9. #9 Re: Getting really Angry over these brakes??
    i have a warranty on the rotors.... what if i go get new ones
  10. #10 Re: Getting really Angry over these brakes??
    Apr 2008
    Rockport, ME
    I'd do that then. Make sure you break them in properly if you get pads at the same time. That might have been what cause the problem in the first place.
  11. #11 Re: Getting really Angry over these brakes??
    utah
    ^^do it...not to be an ass, but these arent some cheapo super special ebay rotors are they?
  12. #12 Re: Getting really Angry over these brakes??
    no .... autozone
  13. #13 Re: Getting really Angry over these brakes??
    what if i tried re-bedding them again?
  14. #14 Re: Getting really Angry over these brakes??
    utah
    autozone might just be the issue...and im being serious. having said that im sure alot of people have used them with good results...
    so guy who works there dont jump down my throat
  15. #15 Re: Getting really Angry over these brakes??
    pep boys pro stop, middle of the road price brake parts have done well so far for me. got them on the regal now all 4 rotors and pads.
    i used them in my truck and they out lasted every other brake pad by over a year. and i drove that truck 30,000 miles a year, so around 60,000 miles out of the pads, all 4 wheels, with over sized tires.
  16. #16 Re: Getting really Angry over these brakes??
    Apr 2008
    Rockport, ME
    It wouldn't hurt to try. Although I doubt that would do the job.
  17. #17 Re: Getting really Angry over these brakes??
    i just went out to re-bed them.... i will do it one more time tommorow just to be sure they get really broken in
  18. #18 Re: Getting really Angry over these brakes??
    Apr 2008
    Rockport, ME
    Good luck man, hope it works out for you.
  19. #19 Re: Getting really Angry over these brakes??
    GTX Level Member cerick08GP's Avatar
    Diagnosing brakes can be tough. However the basics are simple, by merely presenting a flat parallel disc surface to the brake pad will fix most noise problems. I don’t want to point fingers here, but some ppls opinions on grease the $hi# out of them NEVER addresses the root cause of squealing brakes. I will add the only exception to this, the locking bolt needs lube. For those who may be in disbelief, take a look at a new car and show me all the lube. Becuase you won't find any.
    In reading your posts it sounds like you are losing / don’t have proper parallelism. You can “re-bed” pads and replace the rotors until the cows come home but the problem will still be there (unless it gets accidentally fix in the process). Here are some places to start.
    Loose fitting brake pad in the caliper
    Loose fitting or missing brake hardware (i.e. shims, anti-rattle clips)
    Loose lug nuts or caliper hardware
    Debris caught between the rotor and the surface of the brake pad
    Heat cracked rotor
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  20. #20 Re: Getting really Angry over these brakes??
    wi
    I had this on my gtp. taking a hard left they would make noise. one of the metal squeeler's were bent where the pad slides in to the slots. Not the squeeler it selve but that little metal part would hit the rotor and make noise. Sorry I dont know what they call it.
  1. zzp is angry with me :)
    By copperpacecar in forum Off Topic Discussion
    Last Post: 04-26-2011, 07:07 AM
  2. Anybody tried these brakes?
    By PurpleGuy in forum Brakes/Suspension/Chassis
    Last Post: 11-18-2010, 09:36 PM
  3. Help me buy BRAKES
    By MikeZirpola in forum Brakes/Suspension/Chassis
    Last Post: 10-08-2009, 07:07 PM
  4. angry sti driver
    By blowfishRus6 in forum Track Sessions and Kills
    Last Post: 11-12-2008, 12:11 PM
