Thread: axle nut torque specs question
Results 1 to 16 of 16
  1. #1 axle nut torque specs question
    Donating Users kyle91's Avatar
    Jun 2011
    Michigan
    I'm sort of lost on what torque spec should be should be used for my 99 Regal. Some sites say 118ft-lbs and some say 159ft-lbs. Another thing that is odd is why would the grand prix use the same exact hub and parts and only be 118ft-lbs and the regal be 159ft-lbs? Is it more dependent on the hub you have for the torque spec? This is starting to piss me off as I'm going through hubs faster than the damn seasons change. I'm wodering if the hubs I put on (didn't come with torque spec in box and were ebay brands-those should still last longer than a few thousand miles) were 118ft-lbs and because I torqued them to 159ft-lbs, could that actually detroy the hub bearings that fast?
    current mods: DIY FWI, res & u-bend delete, SD headers mated with custom 3in downpipe, 2.5in catback with turbomax muffler, autolite 104s, 180 t-stat, poly mounts, can tune, 3.4 mps
    soon to be mods: NIC cam, possibly dna springs
  2. #2 Re: axle nut torque specs question
    PA
    I always torque mine to around 150 ft-lbs and never had an issue.
    I would rather think your issue is using cheap hubs. Get Timken for $100 from rock auto, torque them to 150ft-lbs and you should be good.
    2001 GSE
  3. #3 Re: axle nut torque specs question
    Jun 2011
    Michigan
    Maybe the cause of cheap ones is the cause in most applications but typically not after 3 or 4 months. Doesn't make sense. If it is though I guess this will be the 3rd hub on the driver's side.
  4. #4 Re: axle nut torque specs question
    Feb 2009
    flintnasty MI
    Get oem hubs, torque to "as much as you can"
    /thread.
  5. #5 Re: axle nut torque specs question
    Charles City, IA
    Yours is 118. They changed the spec in like 99 or 2000 to the 159.
    SMGPFC Two Nipple General
  6. #6 Re: axle nut torque specs question
    Charles City, IA
    /thread.
    Thats retarded the torque sets the preload in the bearing. They need to be torqued.
  7. #7 Re: axle nut torque specs question
    Jun 2011
    Michigan
    well why would it suddenly jump from 118 to 159 when the parts are exactly the same? especially when everyone says a hub for the grand prix can be swapped into a regal and vice versa when grand prixs are set for 118.
    and my car is a 99 so by what you just said it'd be 159.
  8. #8 Re: axle nut torque specs question
    Charles City, IA
    I just looked up the spec for yours on alldata its 118 I mis spoke it was 2000 or 2001.
  9. #9 Re: axle nut torque specs question
    Charles City, IA
    99 grand prix is also 118.
  10. #10 Re: axle nut torque specs question
    Charles City, IA
    It changed in 01, I think it is the axle nut its self that is different.
  11. #11 Re: axle nut torque specs question
    Jan 2009
    Tallahassee, FL
    /thread.
    That's all I have ever done. I don't have a torque wrench that goes to above 110 ft lbs. No problems so far
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  12. #12 Re: axle nut torque specs question
    Jun 2011
    Michigan
    mitchell1 which i have access still from remember my autoshop's login from a couple years hehe says for a 99 to be 118 and 2000 on up is 159. Can anyone explain how GM could raise the torque spec for the next year yet the hub assembly is exactly the same for 98-through 2003 I thought?
  13. #13 Re: axle nut torque specs question
    PA
    Quote Originally Posted by kyle91 View Post
    The replacement hubs are exactly the same. I would guess that GM originally started torquing them to 118ft lbs and then ran into an issue where they thought it would be best to raise the torque to 159 or whatever. But they didn't feel it was a big deal to make it retroactive.
    I have a 97 and have replaced a few hubs and always torqued to 150ft-lbs or so.
    2001 GSE
  14. #14 Re: axle nut torque specs question
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    in 01 the hubs did change you have a plastic abs clip or metal
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  15. #15 Re: axle nut torque specs question
    Jun 2011
    Michigan
    Quote Originally Posted by 1LoudGrandPrix View Post
    lol I don't think a clip change is grounds for 40ft-lbs more of torquing on the nut. So should I try a happy medium say like 130 and just check to make sure it doesn't come loose?
  16. #16 Re: axle nut torque specs question
    SE Level Member Burley117's Avatar
    Nov 2011
    Kalamazoo, MI
    The clip change is not the reason for the torque spec change lol. Often when there is a component or assembly design change they will also look at changing peripheral components (i.e. the clip) for cost savings, minor improvements, etc. I have a 2001 3.8L GP and thus it appears to be a candidate for mid-year component changes.
    I had the issue first of getting the wrong socket. The aftermarket axles that I found used a 34mm nut. So, I went to the store and picked up a 34mm socket. However, the nut on my axle...the original axle...is not 34mm! It's 36mm. They switched from a 36mm to a 34mm nut sometime, I'm guessing mid year 2001, for some design improvement which I don't know. Doing so reduced the surface area of the nut by about 10%...and as a result they probably increased the the torque spec from 118 to 159ft-lbs to account for the change. Obviously 159 is more than 10% greater than 118, but there is also some loss in thread surface area when you drop in size so the 41 ft-lb increase accounts for that as well.
    I'm coming across this stuff now because I am actually replacing my bearing today and also found contradicting information. I welcome anyone to challenge this theory if they know better- but this is the best thing I can come up with as to why there are two torque specs.
    I hope this helps
    -Luke
    06 Grand Prix, 01 Grand Prix GT, 98 Grand Prix GT, 98 GrandPrix GTP
  1. torque specs
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2010, 11:37 PM
  2. torque specs
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2009, 06:59 PM
  3. Torque specs
    By projectGTP in forum General Tech Discussion
    Last Post: 03-25-2009, 07:31 AM
  4. torque specs LIM
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 11-11-2008, 08:31 PM
  5. Torque specs
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 12:47 PM
