Thread: Just flushed brake fluid, and now dark again
Results 1 to 8 of 8
  1. #1 Just flushed brake fluid, and now dark again
    Dec 2012
    Where 4T65E's were born
    Recently I flushed my entire brake system by removing all fluid from the master cylinder, refilling with new, and vacuum bleeding from each wheel until I saw clean fluid come out from each wheel. Afterwards I did some brake testing and took this picture:
    You can tell the fluid was clean. Well now, the fluid is already brown again, not quite the same color it was before, though. The only reason I could think of why, is that the stuff that had lined the walls of the lines from the old fluid, has dissolved into the new fluid. Can anybody possibly explain why/how this happened? I may just flush once more since brake fluid is cheap. The hardest part would be jacking the car up and getting the tires on/off again.
    Sold.
  2. #2 Re: Just flushed brake fluid, and now dark again
    Florida
    We've had that happen a few times in the bikes we work on. If you don't do a pressurized flush, you'll never get 100% evacuation. Drive around for a bit more, and do another flush.
  3. #3 Re: Just flushed brake fluid, and now dark again
    You'll likely never get it to be perfectly clear fluid, the insides of the brake lines arent new anymore so kinda like what happens when water stays in a metal pipe for a super long time, it turns black.
    If the brakes work great and have no issues I would just leave it.
  4. #4 Re: Just flushed brake fluid, and now dark again
    Dec 2012
    Well it hasn't been in there for even 2 weeks yet, the only reason I would think another flush may be good for it, is to keep the ABS pump from getting anything clogged. There is some of that stuff floating in the reservoir now. (The stuff that once lined the reservoir walls from old brake fluid)
    I believe I got nearly 95% of the old stuff out, so the color that has changed doesn't represent 5% of the old stuff mixed with new. It's darker than that would be. I'll flush it once more when there's a day where I have nothing better to do. There will be one, I'm out of school now.
    Sold.
  5. #5 Re: Just flushed brake fluid, and now dark again
    Donating User Odi's Avatar
    Chicago South Suburbs
    leave the brake fluid alone and instead worry about your ebcm working.
  6. #6 Re: Just flushed brake fluid, and now dark again
    Dec 2012
    I'm not a fan of ABS. All of my experiences have been negative so far(winter stuff). The only situation I would like to have it, is when braking hard on dry pavement and the wheels slip. Rarely does that happen though.
    Sold.
  7. #7 Re: Just flushed brake fluid, and now dark again
    St. Louis
    When was the last time you put new front brake hoses on? It could be that they are deteriorating internally and sending junk into the fluid. Just went through a similar issue on my Bonneville like that. After replacing the stuck caliper and 2 new front lines the fluid stayed nice and clean (well, as clean as can be expected for an 18 year old car).
  8. #8 Re: Just flushed brake fluid, and now dark again
    Dec 2012
    I'm pretty sure they're original. I suppose that's possible as well, I didn't think of that. When replacing, I would like to upgrade to the stainless braided hoses if that's not too expensive.
    Sold.
  1. brake fluid
    By donalda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2011, 04:56 PM
  2. Low Brake Fluid??
    By jezzer in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 10:12 AM
  3. brake fluid
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2009, 06:51 PM
  4. UH OH I flushed the trans now i have a whine
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-26-2009, 01:52 AM
  5. Brake Fluid
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 09:27 PM
