Thread: proportioning valve replacement
Results 1 to 9 of 9
  1. #1 proportioning valve replacement
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    Ok a day or two ago i got in my car (98 GTP) and the brakes seemed VERY numb and it was hard to stop the car. So i checked the brake fluid and the thing was almost dry. I filled it up and yesterday i popped the wheels off and found that the proportioning valve is leaking. And, to top it off it looks like the previous owner just tried to seal it up with silicone...really people lol...so im gunna order the part but my question is once i replace the valve with a new one do i have to bleed all four sides or do i need to just bleed the side of with the valve i replaced? or the third option should i bleed all four just to be safe? Also, i herd from one guy that our cars have a "self bleeding system" is this true???
  2. #2 Re: proportioning valve replacement
    swift current,sask.
    id feel safe just bleeding all 4 rather than having mushy brakes. When I did all of my calipers I had to bleed them all 3-4 times to get all the air out of them. I know on some cars there is a bleeder on the abs module but I don't think there is on these guys.
  3. #3 Re: proportioning valve replacement
    Dec 2010
    Lawrenceville, GA
    yeah i pretty much expect to have to be there for a while at each wheel while my fiance sits and pumps the breaks for me while i tighten the screw and watch lol
  4. #4 Re: proportioning valve replacement
    Dec 2010
    Lawrenceville, GA
    oh and last question is there a bleed order for our cars?
  5. #5 Re: proportioning valve replacement
    Grand Rapids, MI
    Quote Originally Posted by Spartanzz View Post
    Not really, but to be on the safe side, bleed in this order: RR, RL, FR, FL.
  6. #6 Re: proportioning valve replacement
    Dec 2010
    Lawrenceville, GA
    yeah starting farthest from the master to the closest just ordered the valve i need so gunna go pick up about 2 32oz bottles and flush the system just to be sure its all new if im lucky the part will get here tomorrow cuz im off work
  7. #7 Re: proportioning valve replacement
    proper order be:
    RIGHT REAR
    LEFT FRONT
    LEFT REAR
    RIGHT FRONT
    As per GM service manual on GPONA.
  8. #8 Re: proportioning valve replacement
    Quote Originally Posted by whiney View Post
    my regal has the 2 bleeders on the abs, when i first got the car the brakes were all mush, so i started to bleed them all, and then found the abs bleeders, and wound up bleeding them every other day for 2 weeks till all the air was out, nice foamy fluid kept coming out, i finally got all the air out, and the brakes haven't been touched since. it was odd because i would bleed the abs till solid fluid came out and 2 days later i had the mushy pedal again, bleed and more air came out, like i said this went on for 2 weeks, then i guess it all the air came out.
  9. #9 Re: proportioning valve replacement
    if you had a tech 2 device... you could bleed it all in one go.
  1. Leaking hydraulics - proportioning valve
    By SJAndrew in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2011, 01:51 PM
  2. valve body replacement
    By Jakescoots in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-20-2011, 07:18 AM
  3. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  4. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
