Thread: Rear STB Differences
Results 1 to 11 of 11
  1. #1 Rear STB Differences
    GT Level Member jmoore4294's Avatar
    So why cant 04+ use a rear STB from a 97-03? Is it because the bolt pattern is different? Or is there some other factor?
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  2. #2 Re: Rear STB Differences
    Never Never Land
    The strut towers themselves are probably different. Different width etc etc.
  3. #3 Re: Rear STB Differences
    You mean the width between the two strut towers or the shape of the strut towers themselves not the same?
  4. #4 Re: Rear STB Differences
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    That's what I think he means. I'm not sure if there's an adjustable or 04+ specific model.
    Maybe Drunkie knows?
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  5. #5 Re: Rear STB Differences
    Quote Originally Posted by Wrongwayislost77 View Post
    Well ZZP sells theirs for the 04+ that's "adjustable". Then there's BMR's "adjustable" ones, but for the rear they state it only fits 97-03. I'd rather buy an STB that has brackets that use all 3 bolts. And for the rear it seems that you can only buy one like that for 97-03 so I was wondering what made them different and why all these vendors say they won't fit.
  6. #6 Re: Rear STB Differences
    London Ont, Canada
    IIRC, the towers are diff shapes.
  7. #7 Re: Rear STB Differences
    Portland Oregon
    I'm using Don Rome brackets on a factory stb for the rear in my 04. They went on just fine for me
  8. #8 Re: Rear STB Differences
    I don't think there is any difference, I'm using coilovers that guys install in the 97-03s and I just looked at advanceautoparts.com to see if the strut top mount in the rear was different, but the 97-03's and 04+ all use the same part number for a strut top mount. So we know that the bolt pattern in the rear is the same, I'm wondering if they adjusted the frame a little so the strut towers are a little further apart, but that would mess too much with the suspension geometry. I do know that a few guys had problems with the ZZP STB fitting because they weren't long enough on their 97-03s, so I'm gonna say that the 04's for the rears are adjustable
    We do have the DR brackets with the OEM STB option as well.
  9. #9 Re: Rear STB Differences
    So logically speaking, if I were to maybe pick up a rear STB with a heim joint (i.e adjustable one), it would probably fit? I'm actually running DR brackets and the GMPP bar in the rear, but as far as I know, the strut tower can still flex. And when student loan refunds get here, I'm doing an overhaul on the rear suspension and figured I'd get a set of STB's with 3 hole mounting brackets for an overall stronger design.
  10. #10 Re: Rear STB Differences
    London Ont, Canada
    or just make your own...
  11. #11 Re: Rear STB Differences
    You've got me there.
  1. GT vs GTP Performance Differences
    By HWYSPEEDER in forum General Tech Discussion
    Last Post: 05-27-2011, 03:22 PM
  2. l36/l26 differences
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2011, 09:20 AM
  3. the differences
    By noom14921992 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2011, 04:00 PM
  4. Air intake differences 05 vs 06+?
    By Alex05GXP in forum 5.3L V8 (LS4)
    Last Post: 07-30-2010, 04:59 PM
  5. GT/GTP MAF differences?
    By pontiackid in forum General Tech Discussion
    Last Post: 05-24-2009, 07:47 AM
