Thread: 98 GS 4T65E fixed alignment Q
Results 1 to 13 of 13
Threaded View
  1. #1 98 GS 4T65E fixed alignment Q
    Donating Users scgonzo's Avatar
    oregon
    Thanks to this forum and others the trans is now spot on.I bought this 98 SC regal with 157k mi. runs awesome bought cheap do to trans when warm would shudder at launch and at WOT it would surge like a clutch pack coming on and off.Serviced it first added lucas,put 300mi no change.Ordered a force motor,finally got around to doing it,it went 2-4-6,had the frame swung out of the way was able to get cover off and back on with no problem.Also replace engine pan gasket, was easy with stuff out of the way.Took 6.5 hrs for all, not counting cleaning tools and floor.Having a rack made it easy.No leaks and trans is perfect.Ive been beating on it hard and no issues.One question I have for the pros,my steering wheel is off center by just a hair to the left.Does someone know if a loosened the frame bolts and made a slight tweek to bring steering wheel to center which way should I try to move it?hope what im asking makes sense.going down the road the wheel maybe off center 1/2 inch,it was perfect before.Thanks for this awesome forum.Gnz,and no im not taking it in to set the toe.
  1. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  2. Alignment
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2011, 10:39 AM
  3. Alignment
    By matt5112 in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2010, 03:51 AM
  4. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
