Thread: Inner rear tire wear
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Inner rear tire wear
    Jan 2013
    Cleveland, OH
    I am going through the same issue with my '07 GT... Inner rear tires worn down to the steel. Had less than 30k miles on it. The middle and outside as well as the front tires could've probably gone to 40k. The tires hadn't been rotated as often as they should have but this still seems like some sort of rear suspension issue. The rear tires seemed to be angled in at the top too much - riding much harder on the inner wall than on the outer. Again, less than 30k miles on it... I'm very frustrated as to what could have worn this badly already. I got new tires and an alignment. The angle in the rear wheels is still there
  2. #22 Re: Inner rear tire wear
    Rotate your tires more often
  3. #23 Re: Inner rear tire wear
    Aug 2008
    Hamilton, OH
    Rotating the tires won't fix the problem; you'll just get more time to destroy four tires instead of two. If you think the lean is still there, check to make sure the alignment was done to adjust toe (lean). Some places don't check toe, amazing as that seems. If they don't check toe in, go to another place that's competent.
  4. #24 Re: Inner rear tire wear
    GT Level Member GMCustomerService's Avatar
    Michigan
    Quote Originally Posted by Chris07GT View Post
    Chris07GT,
    I am sorry you are experiencing this issue with your vehicle. “nlinesk8s” offers a good suggestion. If that does not resolve the issue, I recommend consulting with a certified technician for an inspection.
    If you need assistance finding a technician near you, please PM me your zip code.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  5. #25 Re: Inner rear tire wear
    Jul 2013
    Capron, IL
    Quote Originally Posted by GMCustomerService View Post
    Chris07GT,
    Louis
    GM Customer Service
    And the question still remains....is this covered under warranty?
  1. Tire wear on inside edges in back
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2014, 11:43 AM
  2. Rear left tire locked up
    By mcrosswaith in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2013, 11:17 AM
  3. Rear tire wear
    By heavy duty in forum General Tech Discussion
    Last Post: 01-26-2011, 12:23 AM
  4. Tire wear issue
    By tommygunz in forum Tires & Wheels
    Last Post: 08-13-2010, 08:07 AM
  5. tire wear
    By izup69 in forum General Tech Discussion
    Last Post: 10-13-2009, 06:28 PM
