Thread: What's this sound like to you?
Results 1 to 7 of 7
  1. #1 What's this sound like to you?
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    It sounds like tin when listening to it from the vehicle and only happens when I turn the wheels. It sounds similar to what the control arm is made of, when I tap on the control arm. Anyone familiar with this sound and what it could be?
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: What's this sound like to you?
    i would grease the front end to start with, tie rods and ball joints.
    check the strut mounts, open the hood and turn the wheels see if the center of the mounts are moving.
  3. #3 Re: What's this sound like to you?
    no grease zerks on our suspension...so you need to just replace things.
  4. #4 Re: What's this sound like to you?
    my tie rods have a grease fitting, not 100% sure on the ball joints.
  5. #5 Re: What's this sound like to you?
    Have you got it in the air and inspected yet?
  6. #6 Re: What's this sound like to you?
    Quincy, Mass
    tie rods dont from the factory iirc. ball joints definitely dont.
    No more GP 04 Impala SS Indy:
  7. #7 Re: What's this sound like to you?
    Jan 2009
    ny
    Not yet, working on my truck.
  1. new sound:)
    By beckys2000gt in forum General Tech Discussion
    Last Post: 07-03-2010, 06:19 PM
  2. how to get more sound out of s/c?
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 01:31 PM
  3. no sound!
    By bwhicker649 in forum Audio, Security & Visual Electronics
    Last Post: 12-01-2009, 04:48 PM
  4. new to this sound...?
    By X97prixX in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2009, 01:52 PM
  5. what should i do to get this sound?
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2008, 07:22 PM
