Thread: 99 GT s/c trac off, abs light on
Results 1 to 7 of 7
  1. #1 99 GT s/c trac off, abs light on
    Donating Users joshuaandrew92's Avatar
    Jul 2010
    Bluffton, IN
    At this point i'm almost positive i have a problem with a wheel bearing/hub assembly. The car drives straight and brakes straight it just squeaks a little when i first apply the brakes when slowing down, every time. I know it's not the squealer on the pad or anything with the rotors because they only have maybe 1.5k on them.. Im just not sure how to pinpoint which hub im having the problem with. the lights are on all the time.
    I read that you have to jack the car up and mess with the tires but im not sure how to do it.
    Hands at 12 and 6 position on tire, do i need to push in and pull out on the tire? or try to spin the tire.. also, does car need to be in park, neutral?... just unsure. Thanks!
  2. #2 Re: 99 GT s/c trac off, abs light on
    Charles City, IA
    Have the code read at a shop. Yeah push in and out on the tire at 12 and 6 and 9/3.
    SMGPFC Two Nipple General
  3. #3 Re: 99 GT s/c trac off, abs light on
    Jul 2010
    Bluffton, IN
    How much does it cost to have abs codes read?... i didnt even know they could be read.
    So i need to push in and out on the tires at 12/6 and 9/3, and if i get any movement out of them that hub is bad?
  4. #4 Re: 99 GT s/c trac off, abs light on
    Charles City, IA
    You have to see what is moving to know what is bad. Movement can come from tierods, ball joints, wheel bearing.
  5. #5 Re: 99 GT s/c trac off, abs light on
    Jul 2010
    Bluffton, IN
    well i just replaced tie rod ends and ball joints/bushings/control arms about 2 months ago
  6. #6 Re: 99 GT s/c trac off, abs light on
    Charles City, IA
    so....new parts dont always mean good parts.
  7. #7 Re: 99 GT s/c trac off, abs light on
    Jul 2010
    Bluffton, IN
    ok so i should have the abs code read and have them inspect the suspension and steering too probably
  1. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  2. abs and trac off light
    By mbuchan2 in forum Introductions/Noob Questions
    Last Post: 03-31-2011, 01:54 PM
  3. ABS Trac Off light on
    By imajen in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2011, 09:47 AM
  4. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
