Thread: What rear brakes fit?
Results 1 to 13 of 13
  1. #1 What rear brakes fit?
    SE Level Member Berger's Avatar
    Feb 2008
    New Philadelphia, Ohio
    I did a search for 12" brake upgrade for all four corners and is the only brake system that works for the rears the GXP brakes?
    2003 Grand Prix SE / Redfire Metallic
    GT/GTP body conversion - 3"FWI - 56mm TB - AGX/SSC combo - 077's - GMPP front/rear sway bars - GMPP trailing arms - GMPP front/rear STB with DR brackets - 03 Limited Edition spoiler - 12" Front Brakes
  2. #2 Re: Whay rear brakes fit?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Bear has a setup as well but pretty much yeah, the GXP is the only stock setup that will fit.
  3. #3 Re: Whay rear brakes fit?
    Feb 2008
    thats what i thought. I guess I will keep the rears 11" then
    Thanks
  4. #4 Re: Whay rear brakes fit?
    Greensburg, PA
    Not sure how much youd want to pay for a rear setup but Wbody store has a rear 12" brake upgrade (Im almost positive is the GXP setup) for 600 + shipping. Comes with everything accept lines. If you look through car-parts.com you should be able to find a rear setup or front and rear setup used for cheaper than the new too. (I went through car-parts and it was cheaper shipped for the whole setup used than for just the rear new)
    Mods:3.4 pulley + recommended mods/ F-Body Front & rear GXP Calipers/ GMPP handling upgrade kit + otto strut brace/ SSC Gen 1 Springs on GR-2 struts/ Verde 5 18x8 Rims
  5. #5 Re: Whay rear brakes fit?
    Feb 2008
    Should I select this option for the rears on there website? -> w/traction control (opt NW7)
  6. #6 Re: Whay rear brakes fit?
    Greensburg, PA
    Actually what i did was check the front GXP calipers and called most places with a front listed and asked if they had the rear setup because i found no listings for the rear only.
  7. #7 Re: Whay rear brakes fit?
    Feb 2008
    I called a local yard and they said the GXP and Buick Lacross share the same rear caliper. So is this true? Will the buick rear bolt up then?
  8. #8 Re: Whay rear brakes fit?
    Greensburg, PA
    Im actually not sure about that. Both parts. Someone that has a little more knowledge on this part might want to chime in. If all else fails I guess you could always call up a dealership to see what the difference between the calipers is.
  9. #9 Re: Whay rear brakes fit?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by Berger View Post
    That could be some very good information. Also, where do you guys find GXP parts? I cannot find any information anywhere on anything GXP pre-2004.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  10. #10 Re: Whay rear brakes fit?
    St. Louis Mo.
    Quote Originally Posted by JoshMcMadMac View Post
    That is because the GXP's didnt start production till 2004 badged as a 2005 model until till current I do believe. The pickens at junk yards are going to be slim at best.
    James Shafer
    St. Louis MO
  11. #11 Re: Whay rear brakes fit?
    Waynesboro, PA
    Quote Originally Posted by GeddyLee View Post
    I have definitely seen several folks on forums with pre-2004 GXP's. So is the brake swap from the 2004+ GXP's onto "our" GTP's? I have not seen much on that, just the F-Body swap.
  12. #12 Re: What rear brakes fit?
    Las Cruces, NM
    From my research, the rears aren't the same. But that was also 2 years ago when I did mine and I haven't been on the hunt for info so they may be the same now.
  13. #13 Re: Whay rear brakes fit?
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    Actually... They didn't even release the news that a definite GXP Grand Prix was going to be built until October of 2004....Until then it was only the GXP Bonneville...and that started in 2004...
    2005 Grand Prix GXP, LS4 - MotorSportConnect.com Message Forums
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  1. problem with R1 concepts brakes?
    By Euro in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2008, 09:39 PM
  2. longer SS brake lines (fbody brakes)
    By UR LOSN in forum Brakes/Suspension/Chassis
    Last Post: 03-30-2008, 02:38 PM
  3. Stupid brakes are spungy
    By 8sec-z in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2008, 10:13 AM
  4. Powdercoating brakes/mounts [*]
    By kyle99gtp in forum How To Write-Ups/Tech Tips
    Last Post: 12-17-2007, 03:41 PM
