Thread: Rear upper strut mount
Results 1 to 7 of 7
  1. #1 Rear upper strut mount
    SE Level Member Ryan D.'s Avatar
    Ft. Wayne, IN
    Picked up an 05 GXP a few weeks ago, can definately hear a clunk when turning or going over bumps in the rear passenger side. I'm guessing its the mount, haven't really had time to look at it a ton. What's the easiest way to go about replacing it? Jack car up, compress spring and just unbolt it?
    05 Grand Prix GXP
  2. #2 Re: Rear upper strut mount
    Omaha, NE
    You have to jack up the car, unbolt the 3 bolts on the top of the strut then undo the lower strut bolts. From there the strut should come out. You can go to harbor freight and get some cheap mcphearson style spring compressors to compress your springs, then undo the top bolt in the center of the strut mount.
    An impact wrench really helps on the lower strut bolts and the top center bolt as well as some PB blaster.
  3. #3 Re: Rear upper strut mount
    Ocala, FL
    Jack car up, remove wheel, unbolt strut assembly. Compress spring, remove top bolt, remove strut mount, replace mount, put top bolt back on, reinstall assembly, put wheel back on.
  4. #4 Re: Rear upper strut mount
    most likely culprit is a broken sway bar end link, not the upper strut mount.
  5. #5 Re: Rear upper strut mount
    Ft. Wayne, IN
    Well, I can hear it on that side when I compress the suspension by pushing on the trunk. I can only hear it inside the trunk/car as well, and just on the passenger side...which lead me to assume its the mount. I'll be sure to check the sway bar out too, what should I look for there?
    05 Grand Prix GXP
  6. #6 Re: Rear upper strut mount
    Topeka, KS
    A cracked\broken sway bar on the end link mounting area.
  7. #7 Re: Rear upper strut mount
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    grab the bottom of the sway bar link and push it up n down to see if there is play in it! but sounds most likley like a sway bar link.
  1. Need help with with rear strut mount??
    By 99GTP99 in forum General Tech Discussion
    Last Post: 02-18-2010, 08:27 AM
  2. missing spacer on rear strut mount '06 GXP
    By tta1401 in forum General Tech Discussion
    Last Post: 07-25-2009, 05:19 PM
  3. upper motor mount help please
    By Red_GTP in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2008, 01:28 PM
