Thread: Wheel hub
Results 1 to 5 of 5
  1. #1 Wheel hub
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    Just a quick question. When i turn the the right theres a pretty big humming noise. i can feel it on the steering wheel. and my abs light is on so i know its the wheel hub. what side would it be if it does that when i turn to the right?
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: Wheel hub
    Jun 2011
    Kentucky
    Could be either one on the front, you need to narrow it down because its possible its the rear as well. Put the car in park with the abs light off, maybe when its first started, while its idling turn the steering wheel back and forth if the lights go off its definately one of the front because the rear tires arent moving. If it is the front best thing to do is switch one out and if it doesnt fix it then swap it to the other side.
  3. #3 Re: Wheel hub
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    In my situation, it was loudest turning right and it was the left front wheel bearing.
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  4. #4 Re: Wheel hub
    Donating Users Ca5p21x's Avatar
    Jun 2011
    Sacramento, California
    The bad Hub always makes the loudest noise when you are turning against it.Well at least thats what I was told. Im having the same issue, along with major vibrations when accelerating on high speeds. Going to the shop tomorrow. Ill post my findings..
  5. #5 Re: Wheel hub
    Jun 2011
    Quote Originally Posted by Ca5p21x View Post
    So I have an update on my vibrating issue. I have three horrible tires. One tire is even cupped. Brutal right Suspension checked out cool I.E. Control arm, ball joint, bushings, wheel hub/Bearing, Axle Shaft So have all your tires checked and balanced and see if that fixes your issue.
  1. wheel wax
    By dengnath in forum Tires & Wheels
    Last Post: 01-02-2011, 01:22 AM
  2. Wheel hop (sometimes)
    By SJAndrew in forum Brakes/Suspension/Chassis
    Last Post: 12-15-2010, 10:03 AM
  3. Wheel help!!!
    By 98GT3800 in forum Tires & Wheels
    Last Post: 10-10-2008, 12:45 AM
  4. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
  5. Wheel hub?
    By Mikel2k7 in forum Brakes/Suspension/Chassis
    Last Post: 03-02-2008, 09:22 PM
