Thread: power steering ?
Results 1 to 9 of 9
  1. #1 power steering ?
    SE Level Member trailshredder's Avatar
    Feb 2009
    Central Ohio
    I just replaced my power steering rack because the seals were shot and leaking like a sieve. I flushed the system well before sealing everything up and it worked great for my first couple trips then all of a sudden started working only half the time. Fluid level is where it should be, any ideas what might be causing this? Could my pump crapped out by coincidence?
    02 Grand Prix GT, Silver with all options.
  2. #2 Re: power steering ?
    St. Louis
    Possible. Does it whine more loudly than normal (all these cars seems to have a bit of PS whine).
  3. #3 Re: power steering ?
    Feb 2009
    Central Ohio
    Does not whine at all. It has whined before the rack replacement when the reservoir was low. Seems to mostly do it at idle speed.
  4. #4 Re: power steering ?
    PA
    So your power steering is not working well at idle? I would say you need to replace the PS pump.
    2001 GSE
  5. #5 Re: power steering ?
    put the front end in the air, run the car, turn the wheel lock to lock, check fluid level, top up as required.
    Repeat until the level stays consistent.
  6. #6 Re: power steering ?
    If you need a pump i have one off a car i'm parting out.
  7. #7 Re: power steering ?
    Feb 2009
    Central Ohio
    The fluid is staying at the full mark and it isn't whining.
  8. #8 Re: power steering ?
    Feb 2009
    Central Ohio
    How much shipped to ohio, 43338?
  9. #9 Re: power steering ?
    I live in NW ohio so it shouldn't be to much for shipping. $30?
  1. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  2. Power steering?
    By apierce1289 in forum General Tech Discussion
    Last Post: 03-11-2011, 04:27 PM
  3. Power steering
    By Pontiacman in forum Brakes/Suspension/Chassis
    Last Post: 08-01-2010, 07:46 AM
  4. power steering
    By thelost1123 in forum Engine
    Last Post: 06-07-2009, 10:47 PM
  5. power steering
    Last Post: 04-11-2009, 10:52 PM
