Thread: The Official what you need and how-to for CTS-V brakes
Page 7 of 31 FirstFirst ... 5678917 ... LastLast
Results 121 to 140 of 609
  1. #121 Re: The Official what you need and how-to for CTS-V brakes
    Reading > joo
    CTS-V calipers are the same on the EVOs, G8 GXP, and '10+ camaro SS
  2. #122 Re: The Official what you need and how-to for CTS-V brakes
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by Drunkie View Post
    Reading > joo
    Yeah, I didnt feel like reading the whole thread.
    Thanks hommy.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  3. #123 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Alright drunkie.. i have been looking into a rear setup besides the gxp and i have some questions you might know the answer to lol... ok so what is the main obstacle in doing the cts-v rear calipers?.. if were to do the rear with them and a 13" rotor.. do you think there would be to much rear bias?
    Getting a bracket made wouldnt be a problem if they wont bolt up properly... also i found a rotor that has the correct width 1.10" for the cts-v calipers and correct 5x115 bolt pattern. Do you think there is something here or not??
  4. #124 Re: The Official what you need and how-to for CTS-V brakes
    Houston/Baton Rouge
    I first thought would be the E-brake.
    2nd. Then you need to make sure they have the right offset.
    I do know the rear STS and CTS calipers look very smiler to the GXP's. Just dont know if there bracket will bolt up.
  5. #125 Re: The Official what you need and how-to for CTS-V brakes
    Houston/Baton Rouge
  6. #126 Re: The Official what you need and how-to for CTS-V brakes
    utah
    3400 bucks for that kit? Ha
  7. #127 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Ya those front rotors are made by Brembo i believe... but anywau the e-brake isnt a problem since i wouldnt be utilizing it anyway.. i think within the 5 years of owning the car i have used the e-brake maybe 2-3 times lo.. if i were doing the gxp conversion too i was not going to use it..
  8. #128 Re: The Official what you need and how-to for CTS-V brakes
    First problem
    -you need a GXP hub and relocated e-brake
    Second Problem
    -Does the caliper even boltup to the rear knuckle? If yes cool, if not, okay now you need custom brackets, not the end of the world; but do you extend the caliper out or do you shift it right or left to keep it within a reasonable distance from the center of the hub. When you do the left or right option, you have now shifted where the caliper postion, eliminating its effectiveness in a way because calipers are positioned in certain spots for a reason.
    Third problem:
    -Find a rotor, the OEM CTS-V rotor is 365mm, but does the knuckle bolt-up int he same place, maybe you need a different size rotor. Good luck on that hunt.
    Fourth problem:
    -Master brake cylinder
    fifth problem:
    -Can the rotor handle an in hub e-brake application?
    There is a reason why the 4th gen F-body guys never bothered.
  9. #129 Re: The Official what you need and how-to for CTS-V brakes
    12" vented rotors with the GXP is enough IMO. If you so feel inclined to do the hub swap and e-brake fix.
  10. #130 Re: The Official what you need and how-to for CTS-V brakes
    There is no fifth gen F body.
    At least I got something right
  11. #131 Re: The Official what you need and how-to for CTS-V brakes
    I forgot to mention, I don't redrill rotors. EVER. First off they are designed in a such a way that where the holes are, are balanced Correctly so the rotor goes around and doesn't wobble. 2nd it weakens the rotors. I'll drill out the center bore but that is about it.
  12. #132 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Ya i was wondering about that... i was working with the manufacturer that i got my front rotors from.. trying to see if they would make them with the correct bolt pattern but they said they had no way bc their programs were OEM specs.. blah blah.. so asked for a blank cause i can CNC my own bolt pattern they were hesitant about it.. then manager said no ... im still trying to work out whether this whole thing is doable
  13. #133 Re: The Official what you need and how-to for CTS-V brakes
    By the end, with the cost...no
  14. #134 Re: The Official what you need and how-to for CTS-V brakes
    Houston/Baton Rouge
    First problem
    From what I read about F-body's doing the CTS-V swap on LS1tech they had to do some work to get around the issue a c-clip axle produces. Namely, the issue caused is the axle moving in and out slightly as part of it's normal operation. A floating caliper can tolerate this movement because it works on slide pins. A fixed caliper on the other hand clamps down from both sides, with the expectation of course that the disc is going to stay where it is. Plus the rear is extremely sensitive to brake upgrades. I want to say that running the same pad compound with the multi-piston calipers without altering the proportioning caused the rears to lock too early. Then they had some issues with the wheel speed sensors and ABS system.
  15. #135 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Alright i will prob just go the gxp route then, i want to do something the rear just looks funny now with the stock 10" lol
    Thanks for the responses and input Drunkie and Ridin.
  16. #136 Re: The Official what you need and how-to for CTS-V brakes
    GTP Level Member buickman104's Avatar
    NYC
    Got just about everything. Waiting on Hub centric rings for the rims to make up for the offset and the CTS-V caliper Bolts from the dealer.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  17. #137 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Hmm those rims look familiar! Lol ;-) good luck on the install
  18. #138 Re: The Official what you need and how-to for CTS-V brakes
  19. #139 Re: The Official what you need and how-to for CTS-V brakes
    NYC
    Because I spent money on the Charger Rims which by measurement were supposed to work but didn't. I did not feel like blowing money trying to figure out which other rims may or may not work.
  20. #140 Re: The Official what you need and how-to for CTS-V brakes
  1. Official Hello!
    By KawaFord in forum Introductions/Noob Questions
    Last Post: 08-17-2009, 03:56 AM
  2. Ok its official
    Last Post: 08-11-2009, 06:51 AM
  3. Its finally official
    Last Post: 04-03-2009, 09:57 AM
  4. Its Official; Im......
    By Toofastgs in forum The Rant Forum
    Last Post: 02-20-2008, 12:46 AM
