Thread: The Official what you need and how-to for CTS-V brakes
Page 30 of 31 FirstFirst ... 2028293031 LastLast
Results 581 to 600 of 609
  1. #581 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    What do you guys think about this, regardless of if brackets have to be made?
    http://www.ebay.com/itm/281601604697...%3AMEBIDX%3AIT
  2. #582 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    Why vy used when u can have new for 10 bucks more a caliper
  3. #583 Re: The Official what you need and how-to for CTS-V brakes
    Apr 2014
    Ohio
    Hey guys, just thought I would post that I have a set of camaro brembos I may be willing to sell.
    The fronts are used but the rears are brand new. I would also sell with it a set of pads for both the front and rear. Plus the correct rear drilled and slotted rotors required to make the rear calipers work. And I also am having a bracket Machined right now to make the rear calipers work on a 2001 grand am. I think the bracket may work for the grand prix as well if my measurements are right.
    Halfway thru this I decided to go another route. So let me know if you're interested and I can provide pics.
  4. #584 Re: The Official what you need and how-to for CTS-V brakes
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Quote Originally Posted by turbov6cav View Post
    If the brackets worked on a gp I'd probably buy them off you if you. Brackets that is. Post up some pics of em
    If You Cant Hear The Whine You're Too Far Behind...
  5. #585 Re: The Official what you need and how-to for CTS-V brakes
    Apr 2014
    Ohio
    Their not done yet. Their being completed. But that's the catch. I'm selling the whole kit and whole kit only. Because I'll be using the brackets if I can't get rid of the whole kit
  6. #586 Re: The Official what you need and how-to for CTS-V brakes
    Mar 2015
    Aurora, CO
    This is the best thread ever! Thanks to everyone on here!
  7. #587 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    Quick question. I know you guys said the GXP rims clear, but will the FRONT (7" wide) GXP rims clear without a spacer? I'm assuming you lot were talking about the rear GXPs clearing.
  8. #588 Re: The Official what you need and how-to for CTS-V brakes
    Aug 2012
    Shakopee Minnesota
    Quote Originally Posted by matt270avian View Post
    That is actually the rear size not the front the front size is 18x8 and has the clearence but the 7" rear would need a spacer
  9. #589 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    Haha whoops I meant to say rear. My bad.
  10. #590 Re: The Official what you need and how-to for CTS-V brakes
    GTX Level Member xxpappas13xx's Avatar
    Aug 2011
    Michigan
    So, I have been talking with a buddy who is doing the brembos onto his and i might possibly in the future, but came across this link. Stock c6 z06 rotors for $67 each, compared to gt500 which may be quite a bit more. However, it obviously runs the same lug pattern as the f-body, just wasn't sure if the rotor would be too big or is it another possible and good option? http://www.hoonable.com/brembos-on-a...the-next-stop/
  11. #591 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    Gt500 blanks are about that price why bother having to Redrill or adapt?
  12. #592 Re: The Official what you need and how-to for CTS-V brakes
    Aug 2011
    Michigan
    Quote Originally Posted by 91parkave View Post
    I haven't looked up gt500 prices, just saw this link and figured it could also possibly work. However, you do not have to redrill because the f body rotors fit on w-bodys without needing to be redrilled and thse have the same lug pattern.
    Sent from my SM-N910V using Tapatalk
  13. #593 Re: The Official what you need and how-to for CTS-V brakes
    Sep 2015
    Miami, FL
    I know this is a grand prix forum but to my knowledge my car and these car share many parts so im really really interested in getting new brakes on my car! So i have a 7th gen impala (2004 w/o abs). Want to know if i should be ok installing the ctsv calipers onto my car. My car is far from stock suspension wise. I have done everything to make it handle better and I've been quite successful in my opinion. I've done everything from bigger front and rear sways, front and rear strut tower bars, poly bushings, new endlinks, inner/outer tirods, new steering rack, kyb agx struts, lowering springs, "anti-pogo" washers, bfg comp 2 245 wide tires all around. I just changed my wheels recently and am/have been lacking in the braking department for a while now. My budget is $500-$600 for the front brakes so im looking into the CTS V setup mentioned in this thread. As far as clearance on the wheels i have 19"x8.5" 5 spoke wheels in the front with +40offset in the front.
    This is what I've got so far in my cart at rockauto : http://www.rockauto.com/catalog/rafr...db9843f37cc201 .
    So what im missing now is:
    • ZZP extended stainless steel brake lines (out of stock at this moment somebody point me elsewhere to get extended SS lines if possible?)
    • CTS-V Caliper bolts ? (not sure if these come with the calipers from rockauto parts #1722287/#1722288)
    • Rotors. (in OP he lists 05' mustang GT500 centric blanks #12061089 but im much more interested in centric stoptech sport part #12762076R/12762076L from the 2005 CTS-V im assuiming any CTS-V rotors will fit??)
    • 4x14MM bushing (Where can i get these and where do these go??)
    For pads i'll pick something out from the ctsv pads either stoptech z26 or akebono acts.
    I have the money right now just waiting for a couple answers to the questions i have pointed out above. For the rears in the future maybe later this year or early next year i will get the gxp 12". I attached the latest pic i have of my car with the new wheels. At this point I've done all major upgrades that could be done to the suspension wise. I recently repainted a couple months ago, got new wheels, upgraded all lighting exterior/interior leds 6000k inside and out with hids under a projector with good cutoff to not blind oncoming traffic. I did all the suspension work with brakes being the last and I'm going for appearance right now. Next year i plan on doing all the engine work and will either turbo or swap in an L67.
    With that said, I will be patiently awaiting for answers .
  14. #594 Re: The Official what you need and how-to for CTS-V brakes
    the CTS-V rotors are 6x115 lug pattern, they will not work.
    follow this thread, though. your car is the same as the grand prix brake wise.
  15. #595 Re: The Official what you need and how-to for CTS-V brakes
    Sep 2015
    Miami, FL
    Thanks for the info! So when looking for the centric rotors on rockauto.com do i look under the 2005 mustang gt500 and the 2010 camaro ss?
  16. #596 Re: The Official what you need and how-to for CTS-V brakes
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    Look for the gt500 rotors, the Camaro rotors are 5x120 lug pattern
    Team JB-Weld
  17. #597 Re: The Official what you need and how-to for CTS-V brakes
    Aug 2011
    Michigan
    Quote Originally Posted by dezebe1 View Post
    So are the f-body rotors and they still work
  18. #598 Re: The Official what you need and how-to for CTS-V brakes
    Just so you know, Centric and StopTech are one in the same.
  19. #599 Re: The Official what you need and how-to for CTS-V brakes
    Quote Originally Posted by xxpappas13xx View Post
    But those are 12" rotors. Not 14"
  20. #600 Re: The Official what you need and how-to for CTS-V brakes
    Aug 2011
    Michigan
    Never said i knew about the size, just the lug pattern! Haha
  1. Official Hello!
    By KawaFord in forum Introductions/Noob Questions
    Last Post: 08-17-2009, 03:56 AM
  2. Ok its official
    Last Post: 08-11-2009, 06:51 AM
  3. Its finally official
    Last Post: 04-03-2009, 09:57 AM
  4. Its Official; Im......
    By Toofastgs in forum The Rant Forum
    Last Post: 02-20-2008, 12:46 AM
