Thread: The Official what you need and how-to for CTS-V brakes
Page 29 of 31 FirstFirst ... 192728293031 LastLast
Results 561 to 580 of 609
  1. #561 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    Quote Originally Posted by buickman104 View Post
    Do they bolt right up over the 7inch wide GXP rim as well? Reason I ask is because I see them sets of gxp rims with all 7inch widths on ebay.
    Probably not without a spacer, the rears have a 55mm offset, and the fronts are 40mm. I'll let somebody with the V brakes chime in to be sure though.
  2. #562 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    Quote Originally Posted by matt270avian View Post
    Thanks guys. I'm assuming the 6 pistons will clear them as well? I'm still not sure if I want to go 4 or 6 piston yet because I would have to fab up a rear bracket and parking brake (96 Riviera, steep driveway).
    Just go with 4 piston fronts. And upgrade the rears. Not sure if the riv uses wbody **** but i would recomend stock rears with a front this strong
  3. #563 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    Quote Originally Posted by 91parkave View Post
    That's what I was thinking. We share the same ability to do F-body/C5/GXP upgrades.
  4. #564 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    I have a set of c5 rear calipers if you want, i also have a set of 03 rear knuckles
  5. #565 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    I've never heard of anybody sticking the rears on. Got a thread for it?
    The GPs use a completely different rear suspension than the Rivis. I don't even think the hubs are interchangeable.
  6. #566 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    The c5 caliper works on a gp bracket
  7. #567 Re: The Official what you need and how-to for CTS-V brakes
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Yeah, dont the 96 and down cars have rear drums too?
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  8. #568 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    Quote Originally Posted by Ridin ON Chrome View Post
    Nope, they're discs. The only known upgrade is to swap out the caliper brackets and rotors with the ones off a DeVille DTS/SeVille STS. Rotor size goes from ~11" to 11.7". I already swapped out all the front stuff for F-bodys (more on that here: http://rivperformance.editboard.com/...-brakes#177823 ).
  9. #569 Re: The Official what you need and how-to for CTS-V brakes
    okay, here's the deal with the 6 piston brembos. they bolt directly onto my car and still fit under the stock (18x8.5 +42mm) wheels.
    therefore they should go on in the exact same fashion as the 4 piston brakes, but you're going to want to make sure you have clearance for the wheels depending upon spoke design.
    do it. don't listen to these naysayers.
  10. #570 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    Yeah, but I have a set of 4 rear GXP 18s so I'll probably need to get a spacer to clear them. What kind of rear brakes are you running with the 6 pistons, just stocks? I would think the 6 pistons would completely overpower the small, single piston rears.
  11. #571 Re: The Official what you need and how-to for CTS-V brakes
    i'm referring to my CTS-V (2005) so i already have the 4 piston brembos everyone is running. the rear brakes from my gen to the current generation are the same, but probably painted a different color.
    if 4 piston brembos fit under the wheels i would THINK the 6 pistons would, too. however, you can't quote me on that. it's a guess.
  12. #572 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    Don't the C6 Z06 rear calipers bolt directly up to the C5 rear brackets, which would subsequently mean that they would bolt directly up to GP brackets? Food for thought?
    That way you all don't need to source brackets for the CTS-V rears.....
  13. #573 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    The second gen CTS-Vs have slightly different rear calipers. They will still bolt up the same as first gens, but they have notches on either side of the mounting tabs to clear the dust shield on the second gens.
  14. #574 Re: The Official what you need and how-to for CTS-V brakes
    i know the dust shield are a little different. i am going to have to trim mine to run the rear rotors when i 5 lug swap.
  15. #575 Re: The Official what you need and how-to for CTS-V brakes
    The problem with the 6 piston is the rotor size...he'd have to find a larger rotor with the bolt pattern and what not.
  16. #576 Re: The Official what you need and how-to for CTS-V brakes
    i would think the V2 rotors would work. same theory as to why the fbody rotors work, big holes.
  17. #577 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    Look on page 16 everything needed to work for tge 6 pistons is there
    http://www.grandprixforums.net/threa...light=lecram25
  18. #578 Re: The Official what you need and how-to for CTS-V brakes
    Houston/Baton Rouge
    VEry nice cool deal.
    The more and more I get email subscriptions to this thread. The more I want to do it. I just through on some brand new C5 Z06 calipers last year but these huge V brakes would look so sick behind my rims. The only thing stopping me is I have some nice 16" weld prostars for the track which to be honest not sure if I will ever go back.. UUMMMMMMMMMMMMMMMMM
  19. #579 Re: The Official what you need and how-to for CTS-V brakes
    Nov 2013
    United States
    Are we just going to ignore this, or...?
  20. #580 Re: The Official what you need and how-to for CTS-V brakes
    Houston/Baton Rouge
    From my understand they dont. Now the fronts do.
    Not sure the e-brake would work either.
  1. Official Hello!
    By KawaFord in forum Introductions/Noob Questions
    Last Post: 08-17-2009, 03:56 AM
  2. Ok its official
    Last Post: 08-11-2009, 06:51 AM
  3. Its finally official
    Last Post: 04-03-2009, 09:57 AM
  4. Its Official; Im......
    By Toofastgs in forum The Rant Forum
    Last Post: 02-20-2008, 12:46 AM
