Re: The Official what you need and how-to for CTS-V brakes
buickman104
Do they bolt right up over the 7inch wide GXP rim as well? Reason I ask is because I see them sets of gxp rims with all 7inch widths on ebay.
Probably not without a spacer, the rears have a 55mm offset, and the fronts are 40mm. I'll let somebody with the V brakes chime in to be sure though.
matt270avian
Thanks guys. I'm assuming the 6 pistons will clear them as well? I'm still not sure if I want to go 4 or 6 piston yet because I would have to fab up a rear bracket and parking brake (96 Riviera, steep driveway).
Just go with 4 piston fronts. And upgrade the rears. Not sure if the riv uses wbody **** but i would recomend stock rears with a front this strong
91parkave
That's what I was thinking. We share the same ability to do F-body/C5/GXP upgrades.
I have a set of c5 rear calipers if you want, i also have a set of 03 rear knuckles
91parkave
I've never heard of anybody sticking the rears on. Got a thread for it?
The GPs use a completely different rear suspension than the Rivis. I don't even think the hubs are interchangeable.
The c5 caliper works on a gp bracket
matt270avian
Yeah, dont the 96 and down cars have rear drums too?
Ridin ON Chrome
Nope, they're discs. The only known upgrade is to swap out the caliper brackets and rotors with the ones off a DeVille DTS/SeVille STS. Rotor size goes from ~11" to 11.7". I already swapped out all the front stuff for F-bodys (more on that here: http://rivperformance.editboard.com/...-brakes#177823 ).
matt270avian
okay, here's the deal with the 6 piston brembos. they bolt directly onto my car and still fit under the stock (18x8.5 +42mm) wheels.
therefore they should go on in the exact same fashion as the 4 piston brakes, but you're going to want to make sure you have clearance for the wheels depending upon spoke design.
do it. don't listen to these naysayers.
Bio248
Yeah, but I have a set of 4 rear GXP 18s so I'll probably need to get a spacer to clear them. What kind of rear brakes are you running with the 6 pistons, just stocks? I would think the 6 pistons would completely overpower the small, single piston rears.
i'm referring to my CTS-V (2005) so i already have the 4 piston brembos everyone is running. the rear brakes from my gen to the current generation are the same, but probably painted a different color.
if 4 piston brembos fit under the wheels i would THINK the 6 pistons would, too. however, you can't quote me on that. it's a guess.
91parkave
Don't the C6 Z06 rear calipers bolt directly up to the C5 rear brackets, which would subsequently mean that they would bolt directly up to GP brackets? Food for thought?
That way you all don't need to source brackets for the CTS-V rears.....
Bio248
The second gen CTS-Vs have slightly different rear calipers. They will still bolt up the same as first gens, but they have notches on either side of the mounting tabs to clear the dust shield on the second gens.
i know the dust shield are a little different. i am going to have to trim mine to run the rear rotors when i 5 lug swap. ;)
The problem with the 6 piston is the rotor size...he'd have to find a larger rotor with the bolt pattern and what not.
i would think the V2 rotors would work. same theory as to why the fbody rotors work, big holes.
Look on page 16 everything needed to work for tge 6 pistons is there
http://www.grandprixforums.net/threa...light=lecram25
matt270avian
VEry nice cool deal.
The more and more I get email subscriptions to this thread. The more I want to do it. I just through on some brand new C5 Z06 calipers last year but these huge V brakes would look so sick behind my rims. The only thing stopping me is I have some nice 16" weld prostars for the track which to be honest not sure if I will ever go back.. UUMMMMMMMMMMMMMMMMM
matt270avian
Are we just going to ignore this, or...?
matt270avian
From my understand they dont. Now the fronts do.
Not sure the e-brake would work either.
