Thread: The Official what you need and how-to for CTS-V brakes
Page 21 of 31 FirstFirst ... 111920212223 ... LastLast
Results 401 to 420 of 609
  1. #401 Re: The Official what you need and how-to for CTS-V brakes
    the point here is that even if you wanted to adapt them you'd cost your way out of the calipers immediately. the cts-v calipers are CHEAPER, BRAND NEW.
    get your **** together, dude.
  2. #402 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    ^This...and to add to what Bio said, why invest more money into R&D if it has already been done ya know, we know what fits and it works extremely well
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  3. #403 Re: The Official what you need and how-to for CTS-V brakes
    Ohio
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    not saying it weight doesnt matter and if thats a 2011 i cant find anythimg under 3400 id bet if you weighed your car youd be suprised and dissappointed.
    Anyone that has weighed a new wrx with someone in it, comes to around 33XX.
  4. #404 Re: The Official what you need and how-to for CTS-V brakes
    Jun 2013
    Metro Detroit
    Thank you for saying what everyone was thinking.
  5. #405 Re: The Official what you need and how-to for CTS-V brakes
    Jan 2014
    Northen Virginia
    Hey Drunkie, Do you think the stock SS wheels could be machined down on the inside at the contact point?
    Need to do the brakes asap but just bought new tires and Bilsteins, cant swing new wheels now. any ideas. or can I use the spacers with the stock wheels.
    Thanks Bryan
    703-906-1996c
    Have several questions give me a call if you have a minute or I will try an ping you from work if ok thanks this is flippin fantastic and looks amazing, Also if I have to I do like you wheels what brand make model if it comes down to that and were did you get them?
    Thanks again great work, after this I will be trying to go after putting the rears on this summer if possible.
  6. #406 Re: The Official what you need and how-to for CTS-V brakes
    Banned
    Jan 2014
    Washington D.C.
    Quote Originally Posted by 92builtbird View Post
    Yeah because no one has ever bought parts in a forum classified for far less than new cost...........
    My point was to find out what calipers were compatible because it would make room for more places to search.
  7. #407 Re: The Official what you need and how-to for CTS-V brakes
    Quote Originally Posted by 09 Impala SS View Post
    Thanks Bryan
    703-906-1996c
    I would never machine wheels on a spoke area to fit some calipers, just a recipe for disaster. The best route here is to use spacers if you want to keep your Stock wheels. These calipers fit under the stock GXP wheels just fine, I don't know the specs of the Impala wheels but I can't imagine them being to different.
    My first wheels in the how-to are 18x8.5 Tenzo Tracer 32mm offset, they are no longer made.
    I appreciate the enthusiasm for wanting to do all of this, I don't normally do personal calls outside of the forum, but what I do suggest is keeping your questions public so others can read and learn from there is to offer. I'm not on here as much as I use to be, so others maybe able to respond quicker than I can as well.
  8. #408 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2013
    California
    Do the Rotor heat/dust shields from a CTS-V fit a Grand Prix? (97-03) the bolt pattern looks the same.
    Also, the rotor part number comes up as a 2010 Mustang GT-500 on the Centric web site, just want to make sure.
    Has anyone experimented with any other rotors?
    Thanks
  9. #409 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Gtp419...Yes thats the rotor you need to use its the only one that will work besides the cts-v rotor(which will require machining)
    And 98gpvet these will prob be the only calipers that are going to be direct bolt on. Drunkie did alot of research when he first tackled this project a while back and found that the CTS-V or Camaro SS will be the best calipers to use. If you would like to spend the time and money in researching what other calipers will work, be our guest and post some information that could be used in future projects. But as of right now these 2 are your only options.
  10. #410 Re: The Official what you need and how-to for CTS-V brakes
    Jun 2013
    Metro Detroit
    Quote Originally Posted by 98GrandPrixAfghanistanVet View Post
    What are the odds that there are brembos being sold in the forum classifieds? On the same topic, what are the odds that they are not used? If you're into running used calipers on a brand new set up then I guess that's your prerogative. Not my cup of tea though.
    The R & D has already been done. My calipers were ~$250 Brand new for the set.
  11. #411 Re: The Official what you need and how-to for CTS-V brakes
    Jun 2013
    Metro Detroit
    Quote Originally Posted by GTP419 View Post
    Thanks
    Nope, as stated above, GT500 rotors are the way to go.
  12. #412 Re: The Official what you need and how-to for CTS-V brakes
    Jan 2014
    Bay Area CA
    To clarify I can get away with a 40mm offset rim if I run a 5-8mm spacer correct?
  13. #413 Re: The Official what you need and how-to for CTS-V brakes
  14. #414 Re: The Official what you need and how-to for CTS-V brakes
    Jan 2014
    Bay Area CA
    18x8
    Sent from my SCH-I535 using Tapatalk
  15. #415 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    No it mainly depends on how the spokes are designed... you could have a +30mm offset and the spokes could still not clear.. ask me how i know lol
    Post up the rims you are asking about
  16. #416 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2013
    United States
    Quote Originally Posted by Alix0r View Post
    LOL we know your struggle man
  17. #417 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Haha ya im just glad its all over and i found a rim that works lol
  18. #418 Re: The Official what you need and how-to for CTS-V brakes
  19. #419 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Ya ya Bio...sorry wheel lol
  20. #420 Re: The Official what you need and how-to for CTS-V brakes
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Ok guys i recently purchased a set of cts v calipers got a deal on all 4 so i took the rears. I have read all 21 pages here and from what i know only one person has done the rears. Which happens to be Lecram25. But he is gone and have no other info on how to mock up the rears. Anyone have any info on these i would greatly appreciated will be going on my SLP GTX. once i get the info i don't mind doing a post on here of what all was needed with pics to help others out, i just cant seem to find anymore info on this. Thanks in advance.
    What i picked up.
    If You Cant Hear The Whine You're Too Far Behind...
  1. Official Hello!
    By KawaFord in forum Introductions/Noob Questions
    Last Post: 08-17-2009, 03:56 AM
  2. Ok its official
    Last Post: 08-11-2009, 06:51 AM
  3. Its finally official
    Last Post: 04-03-2009, 09:57 AM
  4. Its Official; Im......
    By Toofastgs in forum The Rant Forum
    Last Post: 02-20-2008, 12:46 AM
