Thread: The Official what you need and how-to for CTS-V brakes
Page 13 of 31 FirstFirst ... 3111213141523 ... LastLast
Results 241 to 260 of 609
  1. #241 Re: The Official what you need and how-to for CTS-V brakes
    SE Level Member TML529's Avatar
    May 2008
    Chicago
    Quote Originally Posted by Drunkie View Post
    Just checked amazon and these are even cheaper now. $104 a piece
    These are Rears The Fronts are 6 Pistons,Am I correct?????
  2. #242 Re: The Official what you need and how-to for CTS-V brakes
    Quote Originally Posted by TML529 View Post
    No those are Fronts, the 1st gen V's were just 4 piston Front and rears; the 2nd gen V has the 6 piston front and 4 piston rear.
  3. #243 Re: The Official what you need and how-to for CTS-V brakes
    May 2008
    Chicago
    That explains it,LoL. Thanks!!!!
    Sent from my HTC One V
  4. #244 Re: The Official what you need and how-to for CTS-V brakes
    No problem
  5. #245 Re: The Official what you need and how-to for CTS-V brakes
    Banned
    Jan 2013
    the bandwagon follower aka noobiee
    dammmmm im gunna try this soon drunk thing u could help me out lol
  6. #246 Re: The Official what you need and how-to for CTS-V brakes
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    I'm gathering up the stuff for the cts-v brakes and I'm confused about the washers and bushings. I'm looking on the McMaster site and don't know which ones they are. Any help?
  7. #247 Re: The Official what you need and how-to for CTS-V brakes
    top 5 dead or alive OmegaRed's Avatar
    Feb 2010
    Medford, Oregon, United States
    drunkie posted the part numbers on the first page
  8. #248 Re: The Official what you need and how-to for CTS-V brakes
    http://www.mcmaster.com
    Part# 6679K16 Desc: Metric Steel-Backed PTFE-Coated Brnz Bearing for 12 mm Shaft Diameter, 15 mm Length Price: $2.45/each Qty: 4
    if the cts brakes are just fancy f bodys in the end, these should work.
  9. #249 Re: The Official what you need and how-to for CTS-V brakes
    GTX Level Member Confusingboat's Avatar
    Minnesota
    I just bought the F-body kit for $40 or whatever it was off ZZP because I couldn't find the banjo bolts anywhere by themselves. Then I just bought a few more washers from Home Depot. Done deal.
    EDIT: I no longer recommend using F-body bolts because of how short they are, but the rest of the kit is fine.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  10. #250 Re: The Official what you need and how-to for CTS-V brakes
    May 2012
    Phoenix, AZ
    I seen the part number and looked it up. Is that all I need for bushings? How about the flat washers? Which ones are they on the website?
  11. #251 Re: The Official what you need and how-to for CTS-V brakes
    the caliper bracket bolt washers id get at a hardware store for sure, 8 cents each maybe? or less. bring a bolt with you, match it up.
  12. #252 Re: The Official what you need and how-to for CTS-V brakes
    Minnesota
    They're just generic 12mm washers. Be prepared to put 4 on each side if you have to. Though I wish I could've found thinner washers to more precisely center my calipers. If you can find .5mm thick 12mm washers grab a bunch of them and you'll be spot on.
    2015 Evo MR
  13. #253 Re: The Official what you need and how-to for CTS-V brakes
    May 2012
    Phoenix, AZ
    4MMX12MM Fender Washer YZ DIN9021 - TEK Material & Supply
    Do these look about right for the washers?
  14. #254 Re: The Official what you need and how-to for CTS-V brakes
    Minnesota
    Inner diameter needs to be 12mm.
    2015 Evo MR
  15. #255 Re: The Official what you need and how-to for CTS-V brakes
    May 2012
    Phoenix, AZ
    So is the thickness of the washer 4mm?
  16. #256 Re: The Official what you need and how-to for CTS-V brakes
    Minnesota
    Quote Originally Posted by Steven Monteith View Post
    4mm in any dimension for this application is way incorrect. The dimensions you need are 1mm thickness, 12mm ID, and 24mm+ OD.
    2015 Evo MR
  17. #257 Re: The Official what you need and how-to for CTS-V brakes
    May 2012
    Phoenix, AZ
    Ok. Thank you. That cleared up my confusion. I'm going to try to find .5mm thick like you said to better align it and that will make it more promising that my rims will fit.
  18. #258 Re: The Official what you need and how-to for CTS-V brakes
    May 2012
    Phoenix, AZ
    How about pads? I know drunkie went with Napa and said Hawks are no good with these calipers. How about Power Stop? Any good?
  19. #259 Re: The Official what you need and how-to for CTS-V brakes
    Minnesota
    I went with EBC Yellow stuff, but they're about $140 a set...grip like mad though.
    EDIT: rather than double-posting, I'm just editing this one. I think it should be noted in the first post NOT to use F-body bolts because they're too short. I've recently had an issue partially because I used them and it ended in the destruction of my driver's side caliper (link to thread). I'd also include the suggestion of thread-locker for people like me who don't default to using it.
    2015 Evo MR
  20. #260 Re: The Official what you need and how-to for CTS-V brakes
    Feb 2010
    i got the bendix pads for $34... f*ck it
  1. Official Hello!
    By KawaFord in forum Introductions/Noob Questions
    Last Post: 08-17-2009, 03:56 AM
  2. Ok its official
    Last Post: 08-11-2009, 06:51 AM
  3. Its finally official
    Last Post: 04-03-2009, 09:57 AM
  4. Its Official; Im......
    By Toofastgs in forum The Rant Forum
    Last Post: 02-20-2008, 12:46 AM
