Thread: Ready to install SSC's? Which is front?
Results 1 to 9 of 9
  1. #1 Ready to install SSC's? Which is front?
    Donating Users GrandpaAl's Avatar
    Salt Lake Utah
    So... Here I am looking at these new SSC springs. One pair of springs is shorter and the wire dia is a little larger, the others are taller w/smaller wire. The short ones are also larger in total dia, which ones go in the front? Got some Bilsteins to put them on, with a new set of Monroe mounts and seats. It took a long time to save up for all of this and I don't want to screw it up. I sent an email to ZZP, but thought I'd get a second opinion from you guys.
  2. #2 Re: Ready to install SSC's? Which is front?
    GT Level Member Tea Time's Avatar
    New Brunswick
    The tall thin ones go in the rear, and the thicker fat ones in the front.
    Think about it for a second....u've got all the weight of engine / trans in the front pushing down on the springs and theres no weight in the rear on the springs therefore u need the heavier spring in the front to handle the weight.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  3. #3 Re: Ready to install SSC's? Which is front?
    Salt Lake Utah
    Makes sense, just wanted to check with others.
  4. #4 Re: Ready to install SSC's? Which is front?
    Salt Lake Utah
    All springs are in and looking good. NOTE! to anyone doing this. If your car is equiped from the factory with 17-18" rims, it doesn't take the common spring seat. There is a slightly larger one for the springs on my CompG, and I assume others too. I tried the standard ones I got from NAPA and the spring wasn't going to stay on them at all, easily a half inch too small. Went back to NAPA with the new parts and a disassembled factory unit and got the right stuff, common rear mounts worked perfectly.
  5. #5 Re: Ready to install SSC's? Which is front?
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    look just sit them on the strut mounts! only the right one will fit snug and in the right position there is an up and a down for it! and i think it is actually the opposite of what tea time said if i remember properly! cuz there was something a bit diffrent about dropping my grand prix but a bit hard to remember i did it a year ago.
  6. #6 Re: Ready to install SSC's? Which is front?
    Did you get the comfort or HD valving?
  7. #7 Re: Ready to install SSC's? Which is front?
    Salt Lake Utah
    I got the HD's. Turner Motor Sports/AllShocks.com worked out to be the best price. The ride isn't any lower, but it's much smoother. I don't know how much of that was old(117k) worn out struts, or mounts, or the twenty bushings(front and back) and the two ball joints I replaced at the same time. I eye-balled the allignment and will drive it around for a week before going to get it aligned. Hopefully it'll settle some by then too.
  8. #8 Re: Ready to install SSC's? Which is front?
    Just curious as I have some HD's with vogtland springs and i've noticed an increase in ride height yet the handling is improved, but only marginally.
  9. #9 Re: Ready to install SSC's? Which is front?
    Salt Lake Utah
    I really like the way this shock/spring combo works. I've always been a proponent of the softer spring/stiffer shock valving. In the late 70's I campaigned a Corvette with a freind in hill climbs and gymkhanna, that was what worked best for us. I'm wondering if a stiffer anti-role bar set-up might be my next change, but right now am VERY happy with how it's all working.
  1. ready for header install...PCM????
    By ionroller in forum 04+ Specifics
    Last Post: 09-02-2010, 03:50 PM
  2. ZZP Front Strut Bar Install
    By 04CompG in forum General Tech Discussion
    Last Post: 08-11-2009, 10:46 AM
  3. Front Sway Bar Install Issue
    By rileystanek in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2009, 11:12 PM
  4. How to install new front speakers on a 97 Pontiac Grand Prix?
    By GothTP in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2009, 07:59 AM
  5. How do I install front license plate on 2006 Gran Prix
    By DMC-12 in forum Off Topic Discussion
    Last Post: 02-16-2008, 11:43 PM
