Thread: Pads for R1 Concepts
Results 1 to 3 of 3
  1. #1 Pads for R1 Concepts
    May 2008
    I recently replaced all the brake pads on my GP with Duralast Golds. If I bought the R1 concepts rotors, would my current Duralast pads be fine to use?
    97 GTP
  2. #2 Re: Pads for R1 Concepts
    St. Louis Mo.
    You can use them, but I have been weary about using old pads on new rotors. Your pads took the shape of your old rotors, and if they were warped or anything, they could possibly been worn in a way that would not mesh to well with your new discs. The pads would have to basically reshape themselves to the new rotors if that makes sense. This mainly the front set of pads I am talking about, seeing as how our brakes mostly use like 80% front brakes as compared to the rear brakes that get worn very little.
    I personally would look for the Posi Quiet ceramic pads, they came with my setup for my R1 rotors and I could not be happier with them. And they are fairly cheap to come by as well.
    The worst you could do is take say the front ones back to Autozone, and say they were failing or something to where they would swap you a new set, if you did not wish to spend the money on new pads. I know that is kind of decietful, but if you dont wish to spend the extra cash, your options are kind of limited. The rear pads should be fine seeing as how they get used so little in our cars. I didnt swap out my rear pads on my old GT until hit 120k miles. That is how little they get used
    Here are some I found on eBay. They are for the Monte Carlo, but they work just the same on the GPs.
    http://cgi.ebay.com/ebaymotors/Posi-...3134QQtcZphoto
    James Shafer
    St. Louis MO
  3. #3 Re: Pads for R1 Concepts
    Barksdale AFB, LA
    Quote Originally Posted by GeddyLee View Post
    eBay Motors: Posi Quiet Front Brake Pads 00-04 Chevy Monte Carlo (item 220241083134 end time Jun-29-08 17:07:49 PDT)
    I didn't think they would without the 12" upgrade...
    2009 Subaru Impreza WRX STI
  1. Cheap rotors/pads from Ebay(R1 Concepts)... You opinion is requested!!
    By Freebeer187 in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2008, 10:07 AM
  2. Reflective concepts
    By jacobmh27 in forum Visual/Body Modifications
    Last Post: 04-17-2008, 08:06 PM
  3. Centric pads and rotors. good?
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2008, 03:44 PM
